Proper Course |
Author | |||
redders ![]() Groupie ![]() Joined: 30 Dec 04 Location: United Kingdom Online Status: Offline Posts: 41 |
![]() ![]() ![]() ![]() Posted: 15 Apr 10 at 1:19pm |
At a wing mark 2 boats arrive one behind the other, both on starboard, both 2 sail reaching, for a port rounding.The slower lead boat is clear ahead. The next leg is a dead run to a leeward mark.The boat in front is a conventional spinaker boat and the boat behind is an assymetric spinnaker boat. As the first boat rounds her rounding is not good and she ends up boat length to windward of the rhumb line and begins hoist her spinnaker up, whilst the boat that was clear astern then gets an overlap within a boat length to leeward,and also hoists her spinnaker. Once kites are set the leeward boat then demands that she wants to sail her proper course and asks the windward boat to head up. At the same time the windward boat demands that she wants to sail her proper course and bears away. There is no contact (lots of noise) and the conventional spinnaker boat clears ahead and sails off down the rhumb line whilst the assym boats after wallowing around heads up and sails away on a reach There was not only the dissagreement on the water but also amongst the sailors at the club about what rules applied. I know what I think what does everyone else think? Would it have made any difference if they were overlapped as they rounded.? |
The older I get the faster I was!
MattK ![]() Far too distracted from work ![]() ![]() Joined: 02 Feb 05 Location: United Kingdom Online Status: Offline Posts: 221 |
Surely, as they were both sailing their proper course its a simple windward
boat must keep clear incident, with the leeward boat luffing, but not above its proper course, so it had right of way, water and overlap shouldn't come into it if they have both rounded the mark at this point |
I haven't got RRS in front of me and I'm sure Gordon will be along shortly to give the definitive answer, but surely in this situation there is no requirement to sail a "proper course" and that it is normal windward boat leeward boat situation subject to the proviso of the leeward boat's responsibilities on initially acquiring right of way?
I would have thought an overlap rounding the mark would change nothing once they left it astern? |
That relevant text in full:
From this (my bold) we can see that the Proper Course of the boat to Windward is irrelevant. The proper course for the assymetric downwind will be to zigzag for VMG. The conventional spinnaker boat must find some way round this- they cannot force the assymetric low.
the Moo- the RRS are available free in pdf form at sailing.org, the official site of the ISAF Edited by alstorer |
Al |
Agree with above posters: Windward has to keep clear, but leeward may not sail above her proper course.
Assuming all agree on the facts above if there was no protest hearing windward should retire. |
Where do the rules clarify what a proper course is? As far as I'm concerned, a proper course would be to aim at the mark, why should VMG come into it? |
Isnt "proper course" the course a boat would sail if the other boat was
not there to influence them - thats what it says in the sailing rules in practice book. So the assy should have headed up to their normal (max VMG) course |
John Hamilton
Proper Course A course a boat would sail to finish as soon as possible in the absence of the other boats referred to in the rule using the term. A boat has no proper course before her starting signal.
RRS P151 - Definitions |
Ex-Finn GBR533 "Pie Hard"
In the definitions:
So yes, its any course that you can convince the PC could be reasonable. Case 14 in the case book illustrates this - it appears to be about two boats in the same class:-
Edited by JimC |
mike10626 ![]() Groupie ![]() Joined: 04 Jul 08 Online Status: Offline Posts: 72 |
Forgetting the rules for a second, isn't this strategically a bad position for the asymmetric boat to get herself in ? If she had remained above the symmetric boat he would have got up to speed quicker and got away. Going below she has to wait until she establishes an overlap, then shout and give the other boat time to get clear before she can power up. I can see it makes sense in a one design asymmetric fleet as this puts you in the controlling position but for handicap racing doesn't it just slow you down? I tend to agree the rules are on the side of the asymmetric boat - just not sure of the logic? |
RS500'S@Datchet - The Country's largest Trapeze Asymmetric Fleet ?
