New Posts New Posts RSS Feed: Epoxy or polyester?
Epoxy or polyester?
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Topic: Epoxy or polyester?
    Posted: 01 Apr 10 at 4:03pm
I have acquired a very old & knackered tasar (638) which I guess is 30 years old.
It has a number of splits where the hull meets the deck.
I am guessing it was built with a polyester resing; and I fix these with epoxy or should I buy "matching" resin?
alstorer View Drop Down
Post Options Post Options   Quote alstorer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 10 at 4:30pm
if the surfaces are well prepared, epoxy will bond well to nigh on anything.
Al
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 10 at 5:07pm
As long as the polyester isn't fresh, your fine, I believe. I always thought
polyester over epoxy is a bit dodgy but the LINK seems to suggest
otherwise, well at least with regard to gel coat.
http://www.boatbuilding.net/article.pl?sid=06/02/14/142213
Edited by Jack Sparrow
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 10 at 5:24pm
Thanks chaps ... I have some epoxey in the garage so I will use that.
I've sort of got it in my head that this boat can only be fixed with stuff kicking around in the garage ... apart from some specalist parts which I will have to buy.
Lukepiewalker View Drop Down
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 10 at 5:56pm
I believe the issue is not one of incompatibility as such, more that the different flex characteristics mean the epoxy will tend to be more rigid and 'pop' off when the underlying poly flexes.
Ex-Finn GBR533 "Pie Hard"
I luv Wight View Drop Down
Post Options Post Options   Quote I luv Wight Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 10 at 8:17pm
The other way round - epoxy is more flexible than polyester ( especially polyester gel-coat which is very rigid and brittle).
Epoxy sticks better too, but it doesn't colour match.
Andy P
foiling Int Moth GBR3467
Freedom 21 Codling
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 10 at 8:39pm
I take it back... what Guru Andy said...
Post Options Post Options   Quote alstorer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 10 at 8:46pm
careful now with your generalisations- I could mix you an epoxy that was as brittle as anything- but I could also make a pure epoxy bouncy ball. They're a remarkably broad range of materials
Al
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 10 at 12:20pm
I've used both for Laser gunwales at various times, and both worked.
