From Trailer to Sail |
BarnsieB14768 ![]() Posting king ![]() Joined: 30 Dec 06 Location: United Kingdom Online Status: Offline Posts: 126 |
![]() ![]() ![]() ![]() Posted: 16 Feb 10 at 2:41pm |
Remember a Hurricane TT at Bala in 1989 - 1990. Finished work (P&O Dover) and drove straight up and we were a bit late. We arrived, went and got changed and hoisted the sails and went sailing and won the event. Had about 12 people rigging the boat
fleaberto ![]() Far too distracted from work ![]() Joined: 12 Jan 09 Location: United Kingdom Online Status: Offline Posts: 302 |
....as long as i don't get the kicker tangled, my Lightning is done in around 10mins. Just wish i could actually sail it as quick!!!!
A lot of it comes down to practice, learning what you can and can't undo and having a system. For instance do you take the shrouds off the boat - you'll find you probably don't need to if you do a bit of jiggling. See if things that are knotted can be left tied or fastened in a quicker way, see what can be left threaded up, see if shackles can be replaced with hooks. All these things help. |
djdhi ![]() Groupie ![]() Joined: 06 Oct 07 Online Status: Offline Posts: 44 |
My second boat. a Mirror, takes about 50 mins to rig from the mast down position, with a singlehanded crew. Iit has more string than a Flying Fifteen. It has the now rather old-fashioned gaff rig. As I have not had it long I would welcome any tips. As it stays outside I have to have a flat cover to keep the rain from getting in, with the mast inside. djdhi |
At my club we once got a late arrival at a Solo Open meeting on the water within 9 or 12 (can't remember which) minutes of driving through the gate...
reckon we have the B14 up and ready in well under thirty minutes from pulling in. If you do a lot of travelling, unless you're a masochist, you quickly figure out time saving set ups.
Plus, we've not got that much string to sort. |
Al |
45 minutes in the Lark if the mast is down (too much string and fiddly kicker). 25 mins for the contender if someone helps with the mast. Garry |
Garry
Crows ![]() Newbie ![]() ![]() Joined: 03 Feb 10 Location: United Kingdom Online Status: Offline Posts: 9 |
9 minutes to perfect. but thats an enterprise and it took 3 mins to get a knot undone.
as for the merlin, if I turn up a day in advance, I am a day late to get the frikken set up right
Edited by Crows |
Enterprise
National 12 Merlin Rocket Laser Solo and whatever else takes my fancy. |
n12fun ![]() Groupie ![]() Joined: 15 Nov 07 Location: United Kingdom Online Status: Offline Posts: 48 |
national 12 from trailer with everything tied in still to fully rigged with sails up in 15 mins if were in a rush ( usualy are)
+2 the lighting is the quickest boat to rig i have ever had ! lightning no 333 Edited by ex laser |
