New Posts New Posts RSS Feed: Flat Trolley tryre
Flat Trolley tryre
Webmuppet View Drop Down
Post Options Post Options   Quote Webmuppet Quote  Post ReplyReply Direct Link To This Post Topic: Flat Trolley tryre
    Posted: 30 Jan 10 at 10:14pm
Hi everyone,
The tyre on one of my launching trolley wheels was a bit soft when I launched the boat this morning and when I returned to shore the wheel was completely flat - it might have had something to do with the water temperature, it really was that cold ! No problem I thought, however, I hadn't realised that the tyre was tubeless and because the seal had broken on the bead, it wouldn't take any air. There are several solutions 1) buy a new wheel/tyre assembly, 2) put an inner tube in the tyre or 3) take it to a tyre fitter with a decent high pressure air-line to see if the bead will seal against the rim of the wheel. Has anyone else experienced this kind of problem and have they any suggestions ?
Cheers,
Nigel
P.S. I did try the airline at the local Tesco's petrol station, but it wasn't very high pressure and didn't sort out the problem
Graduate 2530 'Galaxy'
JohnW View Drop Down
Post Options Post Options   Quote JohnW Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 10 at 11:17pm
Cigarette lighter fuel....
http://www.youtube.com/watch?v=p2HXHFhhHlM
dopamine View Drop Down
Post Options Post Options   Quote dopamine Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 10 at 9:45am
Barney Rubble and Fred Flintstone used solid tyres hewn from stone.
Could always buy a new one, you mean git!
Adam.s View Drop Down
Post Options Post Options   Quote Adam.s Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 10 at 12:16pm
If you cover the inside of the rim and then the tyre in washing up liquid it should seal, well in worked for a trailer wheel anway.
tgruitt View Drop Down
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 10 at 12:17pm
And it will stay clean for ages!
Captain Morgan View Drop Down
Post Options Post Options   Quote Captain Morgan Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 10 at 1:17pm
Trolley tyres/wheels are hardly the most engineered of wheels. I've seen plenty of long-winded and fiddly repairs undertaken at our club, and they never last long.
Buy a new trolley wheel, it's quicker and simpler in the long run.
tomoore1 View Drop Down
Post Options Post Options   Quote tomoore1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 10 at 2:37pm
Put an inner tube in it, i got a pair for about £5 or 6 each. They are the same ones which i put in my trailer wheels (and wheel barrows) so its good to have a spare in the car anyway.
Much simpler than fiddling around to get a good seal and if you get a puncture its easy to fix with a bicycle tyre kit.
Restoring Firefly 517
Post Options Post Options   Quote Webmuppet Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 10 at 4:51pm
Nice bloke at the tyre stockists sorted it out in about two minutes - the joys of having access to a decent high pressure airline.........and just in case, I've ordered a couple of inner tubes from Ebay,
Cheers,
Nigel
