Mirror / Echo / RS |
kurio99 ![]() Groupie ![]() ![]() Joined: 18 Dec 09 Location: Canada Online Status: Offline Posts: 65 |
![]() ![]() ![]() ![]() Posted: 20 Dec 09 at 5:56pm |
I am trying to pick a boat based on the following criteria.
1) Under 70 kgs - I have a bad back and sometimes will be wheeling it to the back yard. 2) High Boom - Bad back. Wrecked it once ducking deep under a boom. 3) Solo - Most of the time, I will be single handed. 4) Family - Occasionally, I (87 kgs) will be taking a child or two. A jib or spinnaker would help reduce their boredom. 5) Reasonably Dry Sailing - Water around here is cold for most of the year. 6) Racing - Probably not, but speed is nice. 7) Under $7k. I narrowed down my options based on local supply (CL, RS) and used boat activity. 1) Mirror - Good sized fleet around here (Ontario, Canada). Real slow. Spinnaker. 2) Echo 12 (Kolibri, Koralle Jr) - No fleet activity. A touch bigger than Mirror. Equally slow. Spinnaker. 3) RS Feva XL - Some fleet activity. My teenager may get a kick out of it. ![]() ![]() 4) RS Q'Ba Pro - No fleet activity. Teenager. Me too big? I know that my size would slow down the RS boats, but slower than a Mirror? Is it true that the RS boats would be unstable with this much weight? Any guidance would help me in this decision. |
The mirror seems to fit pretty well with what you want and I'd have
thought there's plenty available second hand at a complete range of prices so no need to break the bank. I've seen lots of kids paired up in a feva XL at hayling and all of them seem to really enjoy their boat, and I've seen it singlehanded in some breeze with no problems (kite up and everything) by a sailor that's normally a crew not a helm. This could be an Ideal option for you. The Q'ba seems to be a reasonable boat. There's one at my club and the guy sailing seems to get on well with it and enjoy it. Though I don't think it has a spinnaker so I'm not sure how fun it might be with someone else in the boat. It does have a jib though. I'm not sure whether it would have the room for another person....... Captain Morgan is the man to talk to about the Q'ba. Hopefully he may be online soon and give some insight. I don't know anything about the Echo, sorry. If it were me, I'd narrow it down to either the Feva XL or the Mirror. The Feva however would be better for a complete novice crew as it has an asymmetric rather than a symmetric spinny. Edited by Doug.H |
kevg ![]() Posting king ![]() ![]() Joined: 13 Dec 05 Location: Wrexham Online Status: Offline Posts: 120 |
Have you looked at the RS Vareo? |
RS Vareo
It never appears in the local used boat ads and costs $12.5k new, much more than I would like to spend at this time. Nevertheless, thank you for the suggestion. |
Captain Morgan ![]() Far too distracted from work ![]() ![]() Joined: 03 Sep 08 Location: United Kingdom Online Status: Offline Posts: 211 |
Like a pantomime villain, here is the Captain Morgan that you summoned... RS Q'BA: Not sure if 87kg + A. N. Other would work, it should be OK, as the Q'BA has a Design Category "C" (it'll take the weight of 3 people, non-sailing). There is no spinnaker, but the jib is optional. I understand that RS have remodelled the Q'BA now, so that there is more cockpit space for a crew in front of the mainsheet block (which can be relocated for single-handed sailing). Your weight will be fine in the Q'BA, but do bear in mind the fact they are not (usually) fast. It's a modern design, and does serve several purposes, but it is best as an simplistic single-hander, which can be adapted to sailing with smaller crew. I did my back in and found the Q'BA to be a good choice from this point of view, and yes, the boom height is fine. The Q'BA could be well worth a look. The RS Feva: Good fleets, but much more of a youth boat that seems to perform best with two youths/lightweights. I've seen adults single hand them, and they just seem slow and somewhat unstable. I'm not knocking the Feva, but as an adult singlehander, they seem to be poor performers (and I gather, not at all rewarding to sail). The Mirror is possibly the best bet - you have fleets there, they are pretty dry (which could be useful if you intend to mainly potter about in Ontario). Even if you don't race the Mirror, you have at least got a knowledge base and possibly some fellow cruisers around there to exchange tips with. The boom should also be OK, and there is definitely space for a crew. I don't know the Echo, either - but none of the other boats are particularly fast. However, they all provide sensible speeds for cruising/having fun. |
Do any of these boats have an achilles heel? Cracks, breakage, or rips?
For example, the Koralle Jr's were susceptible to cracking around the mast step. One manufacturer's rotomoulded hulls were vulnerable to cracking during the winter time due to thermal expansion. By way of proxy, for their plastic canoes, the Old Town recommends using a thermal blanket and avoiding moving the hull when cold. On occasion, we may see -30c temperatures in the winter at night and I don't have a heated storage area. |
how bads your back?
Mine isn't great... and after hiking hard it kills me. Even in the Mirror with my son. I'm just over 70kg he's 40kg. If you want a bit of speed and stability with a high boom I would of thought a Catamaran would be the way to go. Lightweight would mean you'd want to go for something like a Catapult. from there website: • The design is unique:- a strong, stiff aluminium frame supports slender inflatable hulls.The light weight, only 95 kgs (210 lbs) makes Catapult sensationally fast for a 5m (16ft–4in) boat. • It hit 17.03 knots at Weymouth Speed week with peaks of over 20 knots. • The hull shape (with maximum draft well aft) make tacking quick and predictable, in contrast to other cats WEBSITE LINK |
I'm back after a short break from the forums... Rotomoulded designs cracking in subzero temperatures? I have no idea just how much cold rotomoulded designs can tolerate. -30C is damn cold! I know that Sweden and Norway now have expanding Q'BA fleets, yet they still haven't cottoned on to the Q'BA Owners' Group (which is small and mainly British, rather than being big and international), so I can't ask any of them. Maybe if you get in touch with their RS supplier there might be someone who can answer that type of question (but do bear in mind that these are distributors/salesmen) See a list of dealers here: http://www.rssailing.com/index.asp?selection=Dealer Finder I'm sure that the Scandinavian countries have a great deal of experience with boat storage in the cold. |
