Depowering on a 3 sail Reach |
Steve H ![]() Groupie ![]() ![]() Joined: 29 Jun 06 Location: United Kingdom Online Status: Offline Posts: 48 |
![]() ![]() ![]() ![]() Posted: 07 Sep 09 at 9:49am |
This may sound a silly question, but I'll ask anyway. Which sail should you dump if you need to depower quickly on a three sail reach in a symetrical spinnaker boat? main, spinnaker or jib? Assume this is on estuary waters with a bit of a chop and you get caught by a big gust. Thanks for any help |
Dump the main and bear away.
Roy Race ![]() Far too distracted from work ![]() ![]() Joined: 15 Aug 07 Location: United Kingdom Online Status: Offline Posts: 275 |
Dump the main and bear away as Jim said. If that doesn't do it or you don't have room to bear away, either flap the kite momentarily or blow the halyard and sheet the foot in if it's going to be a sustained problem. Never dump the jib - it doesn't help much and the jib is the one sail that seems to keep you going on a reach. Certainly on a 2-sail reach, it's better to oversheet the jib slightly than undersheet it. Not sure why. |
if you're still struggling once you've let the main out and perhaps can't bear away much then let the kicker off
Edited by laser4000 |
dump the kicker first, lifts the boom slightly and reduces the chance of it hitting the water. Then dump main... then jib.. kite last as in most symetric boats its the main driving force. Always sheet it tight and uncleat the halyard though rather than letting it flog its much quicker and a flogging kite seems to have a massive amount of force trying to knock the boat over.
A big breakfast usually does the trick |
Dump the main and bear away has already been said. However, if you are struggling to stay level ease more kicker, also lift the centreboard, this helps you to bear away (I have a rule of thumb in breezey weather when reaching - I ease the kicker so I can comfortably control the power with the mainsheet and helm, if I'm underpowered it goes on, if continually easing I let some off). Its actually the rapid bear away (20+ degrees) that saves the capsize in the really gusty stuff just easing the main and Kite won't be enough in the big gusts. If we do go past the point of nearly no return either I or crew will dump the kicker completely, sometimes it saves it - but you need it off anyway for righting. You could also try lowering the pole a few inches as this will flatten the spinnaker slightly. |
Garry
What? You always have Chris Evans and Gabby Rosaline onboard? |
Thanks for all the advice. My crew and I are just getting used to using the spinnaker. I had thought about bearing away, but we sometimes skirt a load of moorings and I really didn't want to go through those with the kite up yet. Thanks again |
