New Posts New Posts RSS Feed: Repainting a mirror
Repainting a mirror
jgtsmith View Drop Down
Post Options Post Options   Quote jgtsmith Quote  Post ReplyReply Direct Link To This Post Topic: Repainting a mirror
    Posted: 09 Aug 09 at 9:52am
I have inherited a mirror dinghy which is now 30-40 years old and needs a re-paint as there are several patches of bare wood on the topsides and bottom. Can anyone advise how much a boat builder would charge for this? I've heard some builders "bake" the paint which makes it more brittle and might not suit teaching my son to sail? Any advice?
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 09 at 12:26pm
This is a task I'm about to take on for someone else.  You can't possibly say how much it would cost without seeing the boat, because there are too many variables to take into account, plus you need to check all the wood underneath.  (I haven't assessed my job yet because I haven't had time to have a good look) Depending on what it's like it's possible all the old paint would have to come off, which takes time, then you have to build back up with primer, undercoats etc.
It also depend on what sort of finish you want to achieve and what materials you have used.  Really, it's a bit of a 'how long is a piece of string' type question - there is no hard and fast answer, certainly not a reliable one that can be given over the net.
I would also have to say that refurbing a mirror as I'm doing is not too onerous a task (provided there are no hidden nasties) and is well within the scope of a skilled DIYer.  You might well have to join a queue for a pro to do it, and many might not want to bother.
Whereabouts in the country are you?  I am off to Bala for a week but if you're local to me (Cambridge area) then I'll happily drop by and advise.
ps, I have no idea about baking paint, but I can turn out a nice sponge!
Edited by winging it
hollandsd View Drop Down
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 09 at 1:29pm
oh yes there is
double from the middle to the end....
Laser 184084
Tasar 3501
RS600 698
RS600 782
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 09 at 1:31pm
im not sure about boat builders baking anything, i know that when they apply gelcoat in the mould for a boat when the layup is setting the resin\catalyst reaction creates a lot of heat. A normal 2pack paint would be ideal as it is hard as nails, if not that then something like an international toplac paint.
Dan
Laser 184084
Tasar 3501
RS600 698
RS600 782
Adam MR 1137 View Drop Down
Post Options Post Options   Quote Adam MR 1137 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 09 at 2:06pm
I think when he says baking paint, he means a drying oven like a proffesional spray car body worker would use. I have had my OK pianted by a friend who is a car body repairer and he did an excellent job and the finish quality is excellent. It also means you can put 3 coats on in a day. I have not experienced any brittle problems on my finish, there are a couple of chips now (the work was done in december last year, another advantage of using a drying booth) but know more than you would expect from 2/3 of a years racing.
Merlin rocket 1137
OK 2049
Can be seen at WYC
