GENOA SHEAVE REPAIR |
ian.r.mcdonald ![]() Far too distracted from work ![]() Joined: 24 Feb 06 Location: United Kingdom Online Status: Offline Posts: 440 |
![]() ![]() ![]() ![]() Posted: 16 Jul 09 at 2:24pm |
The Genoa haliard sheave popped out of my Superspar M2- top screw fell out I think! No major damage but haliard has cut into the mast down to the lower mounting screw, and also about 5 mm of the bottom of the cutout in the mast has broken off
is there a sheave with a wider hole mount spacing (72mm) that I could fit so i can fit the lower screw into the mast rather than fresh air? Any other suggestions?
Ian, i'm at blithfield sunday we can have a look if you want? To answer the question i'm not sure that there are, and if this is the only solution it may be a case of asking superspars for advice.
Chris |
Short of some intricate welding, could you bolt through into a small backing plate to 'clamp' either side of the old screw hole. If that makes sense.
Ex-Finn GBR533 "Pie Hard"
Thanks- am going to get a sleeve fixed inside- luckily nothing else was damaged when it went bang
