New Posts New Posts RSS Feed: faded grp hull
faded grp hull
Neal_g View Drop Down
Post Options Post Options   Quote Neal_g Quote  Post ReplyReply Direct Link To This Post Topic: faded grp hull
    Posted: 25 Jun 09 at 1:01pm
fareclea g7 is the one for putting shine back on gel coat
(Redoubt Sc)
Miracle 4040
GP14 13407
tack'ho View Drop Down
Post Options Post Options   Quote tack'ho Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 09 at 7:21pm
I have red topsides on the Byte and use red T cut from halfords every other year, works a treat.
NeilP View Drop Down
Post Options Post Options   Quote NeilP Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 09 at 6:20pm
If it's only faded, don't go through the grades of wet & dry - you'll take far too much material off if you do it properly, and if you don't do it porperly you'll never get the shine back! Flat it thoroughly so it's all evenly matt, but do it with either 1500 or 2000 grit wet & dry. Then wash it off VERY thoroughly and buff it with Farecla (can't remember which one works best on gelcoat, G4 rings a bell) and a hard sponge on a good buffer. Once it's all done, give the hull a few coats of good quality wax to help keep the UV off.
No FD? No Comment!
Roy Race View Drop Down
Post Options Post Options   Quote Roy Race Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 09 at 6:11pm
T-Cut.
Or if that doesn't work, wet and dry it through the grades. 400 - 600 - 800 - 1000 - 1200. Make sure you don't sand through the gelcoat if doing this.
ex laser View Drop Down
Post Options Post Options   Quote ex laser Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 09 at 6:07pm
can anyone give me advice on how to restore some shine to an old lightning hull.
its fine were it was covered by the cover, but has faded lower down.
