New Posts New Posts RSS Feed: Re proofing poly cotton dinghy cover?
timeonthewater View Drop Down
Post Options Post Options   Quote timeonthewater Quote  Post ReplyReply Direct Link To This Post Topic: Re proofing poly cotton dinghy cover?
    Posted: 06 Nov 09 at 5:45pm
oh..and it dissolved the glue holding the velcro together
so if you have some dodgy stitching..it'll fall apart
Too many toys..not enough time
Post Options Post Options   Quote timeonthewater Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 09 at 1:40pm
Just done my Merlin cover!
I must confess I started using fabsil..but it was too expensive and and did
very little coverage
I then used Travis Perkins..waterseal... a bargain compared to the cost of
the fabsil £14 for 1    against £14 for 5litres
although the waterseal uses a white spirit base..opposed to the Fabsil's
Naptha..it absolutely honks...do it outside on a sunny..not in the sitting
room
didlydon View Drop Down
Post Options Post Options   Quote didlydon Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 09 at 11:27am
Yep. i can confirm. brings up a green algae tinged cover like..... well..... whatever the original colour was......... but a bit more faded -  what with all the UV & whatnot........
Alistair426 View Drop Down
Post Options Post Options   Quote Alistair426 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 09 at 1:26pm
Dan,
I've only seen it in 500ml so I'll have a read of the back.
Jim
Regarding pressure-hosing covers...just done my very slimey, canvas one and it worked a treat. Nozzle about 6 inches from fabric was fine... don't hose your fingers whilst doing it though - very sore!
hollandsd View Drop Down
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 09 at 10:56am
dont worry about that, just dont get the nozzle to close, it works well but you need to be careful.
Dan
Laser 184084
Tasar 3501
RS600 698
RS600 782
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 09 at 10:54am
Originally posted by didlydon
..use a pressure washer to clean & blast any green algae & bird crap off first
I think I'd want to be a bit wary of high pressure though! I can imagine blasting the cloth weave apart...
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 09 at 9:14am
depends on the size of the bottle
they do different sizes, i think they do the 500ml right up to the 1 gallon sized containers.
Read the bottle about the coverage and then work it out from there.
Dan
Laser 184084
Tasar 3501
RS600 698
RS600 782
Post Options Post Options   Quote Alistair426 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 09 at 8:53am
Dan,
Thanks. Will one bottle do a whole cover?
Alistair
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 09 at 1:16pm
yes i used it on an I14 cover and it worked wonders, give the cover a good clean 1st then allow it to dry then put the stuff in a spray bottle and then go nuts.
Dan
Laser 184084
Tasar 3501
RS600 698
RS600 782
Post Options Post Options   Quote Alistair426 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 09 at 10:09am
Anybody used the Holmenkol reproofing stuff?
Will one can do a Merlin cover?
And most importantly, does it work/is it worth the money?
