New Posts New Posts RSS Feed: Bow repairs
Bow repairs
Scooby_simon View Drop Down
Post Options Post Options   Quote Scooby_simon Quote  Post ReplyReply Direct Link To This Post Topic: Bow repairs
    Posted: 27 Apr 09 at 11:26pm
A Sok.
Can you get a screwdriver into the hole and move the sides of the hull that are bonded?  Have you "split the seam" ot made a puncture in the bow - they need to be treated in different ways.
1, If you have spilt the seam, you nead to clean it all out with a hack saw back to CLEAN matting and gel, this will look painfull but will give you a STRUCTUARAL bond when complete
2, If just a puncture and the rest of the seam is OK then just filling it should be OK.
Can you take some pictures and attach them here?  I've seen "bodged" bow repairs leak like crazy!
ASok View Drop Down
Post Options Post Options   Quote ASok Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 09 at 7:33pm
Cheers for the info.
The hole is pretty deep, but it sounds like the micro balloons will help fill the gap.  Then it sounds like sanding fun for the afternoon.
Fingers crossed for a nice day soon then.
English Dave View Drop Down
Post Options Post Options   Quote English Dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 09 at 5:19pm
Jeez, you have been in the wars! Just put a reply on
your trolley thread.
If you can see the fibre mesh but not through it (ie
ding rather than actual penetration) then you may be
able to fix it with gelcoat filler (plastic padding
makes it and it comes in largish tubes with a small
amount of catalyst). The white may not be just the same
as the white of your Dart (assuming it's not yellow) but
it depends how much perfection you are after.
Mix up the GC filler and squeeze it all into the wound.
Then sand and polish. The last bit do with "wet" wet and
dry (fine as you can get). Probably take you an hour on
a warm afternoon.
If you can find another D18 it is inevitable that he/she
will have done this before. The bows on a Dart are
notoriously fragile so the first time you do this will
not be your last.
English Dave
Ballyholme Yacht Club
Hurricane 5.9 SX
RS700
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 09 at 4:37pm
We need to know how deep the hole is.  If it is a matter of mm and you have merely scraped off the gel coat then you can replace it with gel coat.  If the hole is deeper then I would fill it with epoxy puffed up by micro balloons, sand that off a tad, then skim it over with gel coat.
ASok View Drop Down
Post Options Post Options   Quote ASok Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 09 at 1:28pm
Ok firstly please forgive my ignorance on this.  My general repairs have been limited to a refurb of an old wooden hornet and some light issues with gel coat.
However, bow on dart meets pontoon and causes damage to the leading edge.  Bit of a mess and a hole circa 1-2cm.  Cleaning thehole to remove fragments, I can now see the inner 'skin' (excuse ignorance of terminology) of the hull. There seems to be a slight gap between the outer gel coat and inner part of the hull.
I'm now looking to make some repairs over the weekend and wanted some advice.  Can this be filled with your normal 'plastic padding' type stuff?  i.e. I mix some up and wedge it in the hole to then sand it off nice and smooth?
Or do I need a gap filling type compound to help it bond?
Or do I need to do something more significant?
Any help gratefully recieved.
Thanks
