New Posts New Posts RSS Feed: Bubbles in gelcoat
Bubbles in gelcoat
English Dave View Drop Down
Post Options Post Options   Quote English Dave Quote  Post ReplyReply Direct Link To This Post Topic: Bubbles in gelcoat
    Posted: 18 Mar 09 at 11:37am
When I do a gelcoat repair, I tend to find little pock-marks in the gelcoat as I am rubbing it down. I am assuming these are little bubbles that I am sanding through. How can I stop this? I am mixing the GC and catalyst thouroughly and the repair area is spotless and dry.
English Dave
Ballyholme Yacht Club
Hurricane 5.9 SX
RS700
Merlinboy View Drop Down
Post Options Post Options   Quote Merlinboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 09 at 12:48pm
i just refill the little bubble holes. Then refinish.
timnoyce View Drop Down
Post Options Post Options   Quote timnoyce Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 09 at 1:02pm
From experience, it is very difficult to stop this from happening. I think they are caused as the gelcoat goes off, the quicker you make it go off, the hotter it gets, the worse the pin holes are. If you have the time make it go off slower but this isn't fool proof.
As Mr Merlin says, you will probably have to re-fil them after. I'd recommend filling the problem area with gelcoat and fillers and then roughly sanding it to shape. Then paint on a couple of really thin layers of gelcoat with a brush. This can then be wet and dried, and then polished to perfection!
Practise makes perfect, and the longer you spend, the better it will look!
A Seabadger View Drop Down
Post Options Post Options   Quote A Seabadger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 09 at 3:17pm
How do you alter the speed the gel coat goes off? heat? More/less catalyst?
I don't suffer from insanity...I enjoy every moment of it.
Alistair426 View Drop Down
Post Options Post Options   Quote Alistair426 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 09 at 4:32pm
A man who knows about these things told me that the best way to avoid small bubbles in your gelcoat is to brush it on. Apparently, the action of brushing chases the bubbles out of the gelcoat. My repairs have been a lot simpler since I took his advice.
