-(1)-202408140552.gif)
| List classes of boat for sale |
| program on bbc iplayer |
| Post Reply   | Page 12> |
| tmoore   Really should get out more     Joined: 01 Nov 07 Location: Wales Online Status: Offline Posts: 880 |  Post Options  Quote  Reply  Topic: program on bbc iplayer Posted: 16 Feb 09 at 12:48pm |
| last night i watched an interesting program about the airbus380 (apparently the biggest commercial plane) on bbc iplayer. now the plane stuff itself was boring. however they also went into the wing design. by having a lip on the wing tips it increased efficiency by stopping tip loss. i was just thinking this could apply to foils aswell. ok with daggerboards its more difficult due to fitting it down the slot. however on the rudder it could work. im not thinking T-Foils here, just a tiny lip say 1cm to eliminate tip losses. this apparently gave the plane 8% more lift. if we got 8% more lift we could have a foil 8% smaller and therefore actually use more power from the rig due to the tripping effect of the board being higher up as well as reducing drag by having smaller boards. RS boats have a slight lip on the bottom of the rudders. (its a piece of plastic pipe running along the bottom edge. i think this is more for durability though. what im wondering is whether this theory is applicable to boat with water being a denser medium and the speeds being significantly lower. | |
     Landlocked in Africa
 RS300 - 410 Firefly F517 - Nutshell Micro Magic RC yacht - Eclipse | |
| Jamesd   Far too distracted from work   Joined: 01 Feb 08 Online Status: Offline Posts: 377 |  Post Options  Quote  Reply  Posted: 16 Feb 09 at 1:56pm |
| ive read this before. possibly in bethwaites bible.about it stopping tip losses, i believe the best solution was to have an upside down V-shape on the tip. rather than a bulb shape. Im sure someone will come along with a decent comment soon
| boatshed   Far too distracted from work   Joined: 12 Apr 05 Online Status: Offline Posts: 457 |  Post Options  Quote  Reply  Posted: 16 Feb 09 at 3:13pm |
| The gates on the ends of the wings help reduce induced vortices. ie, reduce pressue leakage from the underside of the wing to the upper side. Hence the wing becomes more efficient. You could try them on your rudder and I think I saw a National 12 with them many years ago. You could try them on the top of your mainsail ! But I think the eliptical "Spitfire" wing or sail shape is pretty efficient without them. It may be better to have the "gate" on the boom. There is a picture in Marchaj's Sailing Theory and Practice book of a yacht with a very wide boom. The foot of the sail is on sliders. The idea is is let the foot of the mainsail slide to leeward end of the boom leaving a big flat shelf on the windward side acting as a gate. It probably worked but without proper measurement, who knows ? I do think that the foot of dinghy jibs should be cut so they are sheeted tight to the foredeck upwind for the same reasons. And, OKs and Finns sail upwind with the boom on the deck Edit: I've always wondered about the efficiency of loose footed mains. A main sail with a "lens" foot should be more efficient.
 Edited by boatshed | |
     Steve
| Mikey 14778   Far too distracted from work     Joined: 05 Feb 09 Location: United Kingdom Online Status: Offline Posts: 298 |  Post Options  Quote  Reply  Posted: 16 Feb 09 at 9:05pm |
   At the risk of going off topic a bit:
 It clearly makes sense to have your jib touching the deck to stop the air from taking a shortcut under the jib. But by putting your jib lower to achieve this, you are also effectively moving it forwards, thereby reducing the overlap between the leech of the jib and the luff of the main. I'm interested in whether or not this is a bad thing, particularly on a boat like a Fireball which has very little overlap to start with. Given the choice, should we be aiming to have maximum or minimum overlap between jib and main ? | |
| MikeBz   Really should get out more     Joined: 21 Apr 04 Location: United Kingdom Online Status: Offline Posts: 536 |  Post Options  Quote  Reply  Posted: 16 Feb 09 at 9:43pm |
| A fatter-headed sail suffers less from tip losses (than a narrow-headed or pointy sail). If you make a fat-headed sail and can stop the top from twisting off excessively then it's harder for pressure to escape around from the high pressure side to the low pressure side - difficult to explain in words and I don't have the wherewithal to draw a diagram. Bethwaite's book explains how the bent-top 18 rig works so well in this respect. Mike | |
| Noah   Really should get out more   Joined: 29 Dec 04 Location: United Kingdom Online Status: Offline Posts: 611 |  Post Options  Quote  Reply  Posted: 16 Feb 09 at 10:21pm |
   Re the 'end-plate' effect of the jib on the deck vs changing the slot by changing the height of the sail the consensus seems to be that the end plate effect has the bigger benefit, given that - in a Fireball at least - the leach seems almost vertical, so raising the sail off the foredeck has a minimal effect on the slot. As with everything, there is a happy medium to be had... Sheeting angle also has to be taken into account in this equation, but that would open a whole new can of worms.  | |
     Nick
 D-Zero 316 | |
| Mikey 14778   Far too distracted from work     Joined: 05 Feb 09 Location: United Kingdom Online Status: Offline Posts: 298 |  Post Options  Quote  Reply  Posted: 16 Feb 09 at 10:54pm |
   Ah, good answer Noah, and I agree with you that the jib-on-deck thing is very worthwhile, and much more so than
 the jib overlap which it affects. But the verticality of the jib leech is an irrelevance, it's the angle of the luff wire which dictates the movement of the jib back/forwards as it goes up/down. And the sheeting angle can be adjusted to suit the change in position, so we needn't worry too much about that either. Of course, the actual back/forwards movement of the jib on a Fireball over the sensible range of jib heights is minimal, and perhaps irrelevant in the real world. I'm just interested to know, all other factors being equal, whether or not a greater overlap is a Good Thing or not. | |
| Phil eltringham   Really should get out more     Joined: 16 Mar 04 Location: England/Hitchin Online Status: Offline Posts: 1105 |  Post Options  Quote  Reply  Posted: 16 Feb 09 at 11:53pm |
| Given the wind shear and velocity gradient as you move away from the water's surface the tip vortex at the top of the mast is worth more concern than that at the foot. Will expand on this, but its late. | |
     FLAT IS FAST!
 Shifts Happen | |
| Noah   Really should get out more   Joined: 29 Dec 04 Location: United Kingdom Online Status: Offline Posts: 611 |  Post Options  Quote  Reply  Posted: 17 Feb 09 at 11:29am |
| Mikey, Thanks for the jib luff vs leach correction - 'twas late & post beer & curry   I seem to recall that I14's used to have overlapping jibs / genoas, but nowadays they don't. Is my memory OK or playing tricks? What's the reasoning behind this? (Just plain faster / self-tacking / rules re sail sizes ???) | |
     Nick
 D-Zero 316 | |
| mike ellis   Really should get out more     Joined: 30 Dec 05 Location: United Kingdom Online Status: Offline Posts: 2339 |  Post Options  Quote  Reply  Posted: 17 Feb 09 at 3:56pm |
   My 14 has a massive overlapping jib/genoa type thing, but it is a pain to tack with the mast ram in the way, and the foot being about 1 and a half times the length of the gap between the tack and the mast. However it works really well on a reach compared to the other shorter footed jib, but isn't as great upwind when the wind comes up (this might have more to do with overall rig set up than jib shape though).
 Also International 14, 1318 | |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
