Mini Freesail Cat board thing |
![]() ![]() ![]() ![]() Posted: 27 Sep 08 at 7:54pm |
Not sure where to put this, it's a cat in as much as it has two defined
hulls, it's to be powered by a windsurf rig in a hope to make me feel a bit safer putting the hammer down in 25 knots plus. Launched it today, we had no wind, so it was just a float test, see how it rides in the water and i shoved it about to check it would lift onto the plane. It's made of ply, glued, screwed and nailed together from bits costing less than £100. It's been an idea that's been kicking around my head for some years, loads of sketched and doodles but everytime i asked someone to build it they thought I'd lost the plot, which clearly i have, but if I get proof of concept out of it, and it gets through the speed course at anything approaching a respectable speed (anything over 30 knots) and I'll be happy. It's way too heavy, I daren't even weigh it. It's got a three stage rocker, final planing wetted surface a minimal 2.4 sq mtrs, inside two kite bladders should ensure even if it leaks, not too much water ingress will occur, now it's finished you'll notice the winds gone. Ayway i just thought y'all might be interested. ![]() ![]() Edited by G.R.F. |
From sailing Cherubs, I know looks can be deceiving. But I don't think this is going to work very well. Hats of for building it though!
Edited by Ross |
Ross
Here's a bet, and I've genuinely no idea, it hasn't had a rig on it.
But I bet i can get that to go a lot faster than Flat Stanley. Shall we say a tenner? |
Splosh ![]() Far too distracted from work ![]() ![]() Joined: 13 May 07 Location: United Kingdom Online Status: Offline Posts: 497 |
Hi GRF. Well done, she does look like a fast bit of kit Also whats the idea of the angled fin? is it just a anti-weed one or does it give it a boost of performance? And finally could we see a piccy from the top? Looking good though! Mark. Edited by Splosh |
RS300 - 346 :D
G.R.F, your on! As long as you tow me there an back!
Angled fin, bow up trim? |
Ross
The weed fin was an idea I'd had a while back to reduce drag, I was going
originally without a fin, then I had this idea for a fin'wheel' then given so much experimentation best to prove one thing at a time. Weed fins are foiled at that angle so you're not dragging the foil by sweeping it back. Straps and pads not in place yet, wanted to sail it first, get a feel for where I'll need to put them.. No need to steer it really, speed sailors just blast down a straight course, get off the other end, turn their board around and sail back, no need to even gybe. ![]() |
How much sail is it going to be carrying?
Ross
looks like it would be quite interesting to watch
good luck with it Graeme, remember to get some video of it moving. Ross: seeing as it will take a windsurf rig im sure it will be able to carry a silly amount of sail area, right down to the damn right small in a blow |
I have a very light 9.5 mtr rig, which is bigger than a moth.
I will also use my variable luff curve invention from a couple of years back, a 7 mtr I managed to get through the course in a 48 knot wind, but the board I was using back then was slow. There's a bit about it here it's good for 31.5 knots on an old dog of a board. Anyway we can talk all we like, the proofs in the pudding, but it'll be fun using stuff I've built myself, I'm usually totally useless at making things, i can design them, but make them happen.. no chance. |
GRF - what's the thinking behind why it should be quicker than a single hulled board? It reminds me a bit of a pair of waterskis held rigidly together, with a fin poking down... |
