Single Hander Questions |
Pipedreams
Joined: 08 Aug 08 Location: United Kingdom Online Status: Offline Posts: 1 |
Topic: Single Hander QuestionsPosted: 12 Aug 08 at 10:12pm |
Hi there I’m a long term lurker looking for some advice on a class I came relatively late to sailing and am somewhere between a novice and I have owned and sailed a laser, where this was the only class sailed, I don’t want anything with too steep a learning curve, particularly The options I am considering with my thoughts on them, nothing seems to Blaze Probably where my heart lies. Byte CII Towards the top of the weight range, is it going to be dog slow to sail Supernova I understand that this is very similar to a laser with much better |
tmoore
Joined: 01 Nov 07 Location: Wales Online Status: Offline Posts: 880 |
Posted: 12 Aug 08 at 10:30pm |
i once sailed a byte (with their small, brightly coloured rig) and is was absolutely horrible. felt like a laser with about 2foot cut off the back and VERY heavy sheeting. this may not have been rigged correctly though as i cant believe a bethwaite boat can be such a dog. last year i was looking at singlehanders from which to move out from a laser and at about 68kg was sort of in the same boat. i went for an rs300 but from the sounds of it they might be a bit much for the amount you sail. cant comment on either of the other two's sailing wise but the blaze is very popular and once you have the mast up its simple to hoist the sail do the rudder and board and off you go.... another thought, how about the streaker? again not sailed one but they are fairly light and apparently easy to sail yet tactical and relatively fast.... worth a look i think. hope this helps tom |
Landlocked in Africa
ifoxwell
Joined: 05 Jan 06 Location: Hoo Online Status: Offline Posts: 669 |
Posted: 12 Aug 08 at 10:48pm |
From the boats you suggest I'd get the blaze. I'm the same weight as you and along with the 29er its only only boat that I would happily take out in any weather, even though as you say, we are a bit light for them. You wont know if you like it until you try it so id suggest talking to the association, there a real friendly bunch, and swould sort you out a test sail, or do what I did when I was first considering a Blaze, just buy it and give it six months to see how it goes. There in such demand that if you dont like it you'll sell it again easily enough. Like Tom I dont like the Byte, and I dont find the new rig any better, its just to bendy for me and I found it hard to keep the new sail under control. Especialy when the Europe is the same size boat but considerably nicer to sail. In fact you could do a lot worse than a Europe. Dont be put off by the low boom however they are quite technical to sail if you want to get the best out of them. Cant talk about the Super nova I'm afraid. Never appealed so Ive never had one. Ian |
jeffers
Posted: 13 Aug 08 at 8:52am |
Hi Pipedream,
I has a Blaze for 2 years but it was on much more restrictive waters than you. I loved the boat but it does need open water to stretch its legs as it tacks pretty slowly. I am sure Blaze720 (the current national champ) will put his 2p worth in at some point. As for your weight there is a guy in the fleet who is about 68kg and sails a very old boat (but he has kept it is very good order) who is always there or there abouts at the nationals (I think he was 3rd or 4th last year). When it gets windy you just wind the cunning on, if it gets seriously windy use some kicker! I used to love mine when the breeze got up, it would blitz pretty much everything and it is comfy too. Cant really comment much on the Supernova having never sailed one but they just don't look quite right when sailing. A guy at my club has one of the new ones and he has had a few issues with the hull. I believe he is getting a replacement hull, so we shall see how that works out. |
Lukepiewalker
Posted: 13 Aug 08 at 7:17pm |
I do know someone who sold his FRP Solo because it picked up dents a bit too easily for club sailing.
There's always the OK... |
Ex-Finn GBR533 "Pie Hard"
laserboy404
Joined: 14 Mar 08 Location: United Kingdom Online Status: Offline Posts: 146 |
Posted: 13 Aug 08 at 9:25pm |
I can beat our only supernova in my laser in most conditions, however, he has the edge in light winds due to fully battened sail etc. another option may be the phantom, but you would be at the bottom of the optimum weight range. |
Laser 159392
Javelin 53 |
timeintheboat
Joined: 01 Feb 07 Location: United Kingdom Online Status: Offline Posts: 615 |
Posted: 14 Aug 08 at 8:15am |
The streaker is certainly worth a look - a potential bandit on handicap.
The supernova isn't a bad boat and good value. When the wind blows they can are quite powerful. Like a laser to sit in (a bit more room) - but not like a laser to sail. |
Fraggle
Joined: 28 Feb 07 Location: United Kingdom Online Status: Offline Posts: 220 |
Posted: 15 Aug 08 at 8:51am |
Supernova sounds ideal. My Dad sails one at Haversham, where they have a huge fleet. Not sure where your based but contact anyone at Haversham and you'd probably be able to get a sail on one to have a try. You don't seem to have to hike as hard in the supernova as in the laser (My Dad really doesn't agree with hiking and is still getting very reasonable results). The fully battened rig gives it good lightwind speed but I am usually up with or ahead of them in my radial when it blows. Streaker is the other option that sounds like it might suit but I've never sailed one so can't comment. |
tack'ho
Joined: 08 Feb 06 Location: United Kingdom Online Status: Offline Posts: 1100 |
Posted: 15 Aug 08 at 2:22pm |
Ok I sail the CII and a Europe so: 70-75KG your right at the top of the weight range to be competetive at opens but I guess as longs as you stay 75 or under you'd be fine handicap. Actually they are very quick in light airs (new rig), I regularly beat lasers on the water in quig-doh conditions. 'feels like Laser with 2 foot chopped off'....mmmm oh yer and a decent size cockpit, more comfy hiking position and far narrower waterline....in fact it feels nothing like laser!! Sheet lods can be high if you only rig 3-1 but with the option to go anywhere between 3-1 and 5-1 you can pick your own sheet speed vs purchase. The new rig is cracking, I sail at 70kg and have no trouble keeping it shut, if you did get one PM me for heavyweight set up. Unfortunatly the boat has been stiched up by the RYA with a shocker of a trial number because of the new rig. Same as a Europe!! I own both and I can tell you now the only time you'll sail to the same handicap as a Europe is in a F1-2, and possibly a f5+ The Europe hull has a nicer feel in waves than the Byte and is a bit more comfy to hike (not that the byte in uncomfy), however the rig isn't as good. You hve to expend a lot effort on working the controls to get the best out of it. Where as you get similar amounts of drive out of a smaller rig on the Byte and it's simpler to manage. The europe will carry your weight better and you can get the right band of mast to suit your weight. The low boom is only a pain in light airs any other time it pops up nicely when you relase mainsheet tension. In short I enjoy sailing both and either would be a suitable boat. Edited by tack'ho |
Thunderchild
Joined: 03 Nov 06 Location: United Kingdom Online Status: Offline Posts: 44 |
Posted: 23 Aug 08 at 7:09pm |
one word- Unicorn.
Nothing better as a single hander and can be suited to all weight ranges. I miss mine!!! |
Currently
TBC! Previously Flying Dutchman K220 Int Moth K3822 Magnum 5 1961 5o5 Parker built K1305 Phantom K99 Europe K156 Unicorn K1065 Dart 18 5o5 Laser K5450 Enterp |
