D12 stretch charastics |
![]() ![]() ![]() ![]() Posted: 23 Jun 08 at 9:23pm |
Anyone know roughtly how much D12 (3mm and 4mm) will stretch once loaded. Trying to make a couple of things but don't have any experience with D12 so want to know how much stretch I might get 3mm will be for trap lines, the wire is 5.9m long, how long do people think I should make them in D12 to allow for some stretch. 4mm will be used for Spi pole supports and so these will be around 1 - 1.5m long. Many thanks
Simon |
Dyneema doesnt really 'stretch' much at all, but it will 'creep' and it wont really stop creeping for the lifetime of the line (which is limited if left out in the sun)
For the trap lines its a good idea to put a sliding splice on the bottom so you can 'coarse tune' the trap height for different conditions so you wont have a problem there. With the spi pole supports you may have to redo the splice every now and again but Id be surprised if you see any real difference with that length of line in that aplication before you should be thinking about replacing the line anyway. If your worried you can overspec the diameter slightly, though what youve got sounds about right to me |
Thanks Not sure what you mean by a sliding splice? |
You might have heard it called an adjustable splice? its an eye splice where the tail is burried for about one and a half fid lengths and then exits the splice and is left long.
With no tension on the line and the outside of the splice bunched up you can freely adjust the size of the loop and the effective length of the line - with tension on the line though the splice binds up without slipping. Think chinese finger trap. The big advantage is that you can roughly set the height depending on the conditions, which means less line is needed in your main adjustment and theres less dangling around your feet on the light days. Edited by Isis |
Ahh, OK understand. Thanks |
Follow up question... How well does D12 "go around corners" and handle knots? Do I need to put ferrels in for high load areas ? Can I put fig 8 knots (with bobbles against) in it to make "stopper" strops for attaching things to? ta
Simon |
I got d12 littered about the boat no probs with corners , gnotts or so , but , a man of yur means could afford some v12 , far superior for pole supports etc , used to have it on my sx and it didn't move , the d12 doing same job around pole does change length and not permantly , ie it shrinks and stretch's , but after 2 seasons I'm no longer worried by slack pole lines at times , it doesn't seem to matter .
as for trap lines folk use d12 frequently , but I'm wary of getting one wrapped round my neck if things go wrong , I know it can happen with wire , but its more unlikely and sailing solo theres no one close to get you out.
i've a short length of 3mm d12 joining the two halfs of the stealth down haul system through the clew , withbowline over a bobble one end and tied to the shackle of the blocks other end , and you know how much force goes on that , i do have a safety back up though just in case .
I'm skint with a capital F... just had to put 4 new shoes on the scooby. That was not a plesent experience... |
v12 is better in many respects but far worse in terms of UV degradation so you may have to replace sooner.
As far as knots go, all knots create weak points in lines... Ive heard of bowlines reduces breaking strength by about 60% whereas a really good eye splice will only reduce by about 10%? Idealy with a stopper knot for a bobble a bulge of whipping twine might be a better option though but be surprised if you have any problems with a knot. As for corners a thimble in the loop will spread the load and cut out any chafe if your worried and they dont cost much |
Linky-plinky - full spec downloadable, including load vs. extension.
