Protest when OCS? |
English Dave
Joined: 10 Aug 06 Location: Northern Ireland Online Status: Offline Posts: 682 |
Topic: Protest when OCS?Posted: 12 Jun 08 at 9:21am |
OK, this happened to me on Sunday in Galway. Downwind there was a standard port/starboard with a singlehanded FX1. I hailed (I was on starboard). Nothing. Now we were getting bloody close and both flying kite so I hailed again. I don;t think he had seen or heard me so he pannicked and crash gybed less than a boat length dead ahead before losing control and bearing off into my flank. So I invited hime to do his turn (cats only do 360) and when he showed no sign I protested.
In the protest room. I was adivised bu the panel that I was OCS and did I want to proceed. I replied that I did because of the contact between the boats. I subsequently won the protest so that I was OCS and he was DSQ. Question. Was I being petty and should I have let it go seeing as his DSQ wasn't going to help my result? |
Contender 541
Posted: 12 Jun 08 at 10:49am |
Disregard of the rules and the penalties incurred is indemic. Protest was correct in my view That said a warning off the water - fail to do your turn again and I will be forced to protest you - would have been favourable
Crew on 505 8780 |
Spyderman
Joined: 27 Feb 08 Location: Netherlands Online Status: Offline Posts: 39 |
Posted: 12 Jun 08 at 11:22am |
Sounds to me the PC was fishing for an easy way out of the hearing.
Maybe they a lot on their plate. From a rule point you don't lose any rights when you are OCS. You still have r.o.w. or have to keep clear when the rules say so and you can still protest. Your protest served two purposes; to learn the other sailor to abide by the rules and in case of fault do his turn(s) and because of contact - which may have caused damage - have a conclusion of the PC which most insurers will accept. |
Are you interested in the Racing Rules of Sailing? Go to: http://rrsstudy.blogspot.com
Posted: 12 Jun 08 at 11:31am |
You did the right thing. Rule breaches are rule breaches.
Scooby_simon
Posted: 12 Jun 08 at 12:13pm |
totally agree; otherwise people do not learn the rules and we get chaos! |
English Dave
Posted: 12 Jun 08 at 12:54pm |
Thanks guys. In 30 yrs of sailing this was the first time inside a PC room, although I have sat on a panel.
Fortunately the impact was merely a glancing blow and there was no damage to either boat. I can see the merit of the "informal warning" other than that I'll probably not be sailing at Galway for another 2 years. I proceeded with the protest because of the two points Spyderman made. The other sailor was really struggling with his boat. Spinni sheets running around the front of the kite. Because of that I suspect he didn't see or hear me, being preoccupied with an incorrectly rigged spinnaker. Notwithstanding, Port/Starboard is the first rule you learn and the penalty of one turn is explicitly mentioned in the SIs (cos it's an amendment to Rule 44 for cats). |
alstorer
Posted: 12 Jun 08 at 1:05pm |
Remember the DSQ may not have directly affected your results, but there's more than two boats in this race I'm assuming?
gordon
Joined: 07 Sep 04 Online Status: Offline Posts: 1037 |
Posted: 14 Jun 08 at 4:00pm |
The DSQ may not have affected your result in this race but it may have an impact on the result of a series. Two points: 1. It is not a bad thing to get a reputation as someone who will protest if the have a legitimate grievance. As the reputation develops other boats in the fleet will be acutely aware of your presence and keep out of your way... 2. There is a tendancy in many clubs to try and avoid protests. as a result many legitimate protest are found to be invalid, or having no point as they don't affect the results. As a judge, especially if there has been contact, I believe that I should do my best to hear a protest, and only find that the protest is invalid when there really is no other possibility.
Finally, English Dave - if ever you need a NJ at a cat event anywhere on the island I'd be more than pleased to help.
Fraggle
Joined: 28 Feb 07 Location: United Kingdom Online Status: Offline Posts: 220 |
Posted: 17 Jun 08 at 3:45pm |
Definitely right. In the laser fleet as so few protests are taken to the protest room no one takes you seriously. I've protested twice and on both occasions the person I protested failed to show up as obviously didn't think I would go through with it!
sstannard
Joined: 26 Sep 07 Location: United Kingdom Online Status: Offline Posts: 14 |
Posted: 26 Jun 08 at 10:48am |
English Dave, what would have happened if he had not crash gybed? It sounds like there'd have been a collision... which raises the question in my mind: at what point should someone in your situation have taken avoiding action. I'm not saying that you should (as I don't know), but I'd be interested in what people think. There's the overriding requirement on all of us to avoid contact, but hiw does that affect your rights? |
So L'Eau - Shadow 067
White Tiger - Spitfire 076 Animal - Nacra 6.0 GBR400 |
