New Posts New Posts RSS Feed: IRC sailing rules
IRC sailing rules
RobC View Drop Down
Post Options Post Options   Quote RobC Quote  Post ReplyReply Direct Link To This Post Topic: IRC sailing rules
    Posted: 18 May 08 at 7:37pm
Is there a rule governing the use of a headsail along with a spinnaker, i.e. sailing with three sails, except fo the purpose of a sail change?
Spyderman View Drop Down
Post Options Post Options   Quote Spyderman Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 08 at 4:04am
RRS has a few rules about sails:
50.1 Changing Sails
When headsails or spinnakers are being changed, a replacing sail may be fully set and trimmed before the replaced sail is lowered. However, only one mainsail and, except when changing, only one spinnaker shall be carried set at a time.
50.2 Spinnaker Poles; Whisker Poles
Only one spinnaker pole or whisker pole shall be used at a time except when gybing. When in use, it shall be attached to the foremost mast.
etc.
You may set three sails, there's no rule stating that you have to lower your headsail when you set your Spi.
Edited by Spyderman
Are you interested in the Racing Rules of Sailing? Go to: http://rrsstudy.blogspot.com
Stefan Lloyd View Drop Down
Post Options Post Options   Quote Stefan Lloyd Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 08 at 7:24am
No. We used to do this on a small IRC boat when using the jib in a breeze, since it avoided the weight of the bowman on the bow during the douse. However genoa+spinnaker = slow.
Edited by Stefan Lloyd
RobC View Drop Down
Post Options Post Options   Quote RobC Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 08 at 10:11am
Yes/no? - the above echos the discussion on our boat during our last race when a competitor was flying 3 sails on a long down wind - as the tactican it was my understanding that it was illegal under IRC rules, as per spydermans comments, & I agree that it would adversely affect out own performance but may affect a protest decisions.
Post Options Post Options   Quote Stefan Lloyd Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 08 at 11:59am
Spyderman said "You may set three sails, there's no rule stating that you have to lower your headsail when you set your Spi." and I said the same. RRS allows it and there is nothing in IRC that overrides that.
IRC rules may be found  http://rorcrating.com/ir2000/irc/2008/IRC2008_Rule_Final_710 26.pdf should you wish to read them yourself. Rule 26.3 is the relevant section.
