Kids boat? |
![]() ![]() ![]() ![]() Posted: 31 Aug 07 at 12:08am |
Funny the Splash is designed for 45kg upwards. The next step after the
Optimist. Recent winning helms ( female ) range from low 50kgs to top
60kg's. It is very depowerable. But there again I am no fan of the
Topper or Pico. If the Splash is to much then an Optimist. Two up a Mirror.
I'd have said a Splash would be much too much for a 36kg, 5ft sailor. It didn't seem inappropriate for me when I sailed it and I'm 65kg and 5' 9" and I'd agree with Nick A that it's more a Radial alternative (albeit shorter, slower and more rolly than the Radial which I preferred). Personally I think the Topper is a cracking little boat - great fun yet pretty vice-free, and even quite small kids seem to be able to right it when capsized - surely a very important confidence point. I'm sure that at 85kg you're better off with a Pico, Nick, but for someone less than half your weight... I thought the Tera was more of a pointy-bow alternative to the Optimist rather than the Topper, and at 36kg maybe that's the territory your sister is in, but if she can handle a Topper (maybe with the small sail or reefed at first) then that's the one I'd go for. |
Paul Handley ![]() Newbie ![]() Joined: 24 Aug 07 Location: United Kingdom Online Status: Offline Posts: 11 |
At around 36kg and 5ft tall your sister is the ideal size for an RS Tera Sport (3.7m sail) and it has a centre mainsheet. I suggest you also look at my comments on the Tera in the 'Tera v Topper' topic. The Tera is great value but not at the expense of quality, plus it is made in the UK! |
The splash is a great boat - but more a laser radial alternative than a topper / pico alternative surely. I'd go for a pico over a topper 'cause it can take two, has a bit of a jib, has a racy sail option and is suitable for adults in huge winds (and it'll certainly plane in a force 7 even with 12 stone in it!). The terra looks really good though - and exceptional value too. Are they making them abroad using slave labour perchance? |
Javelin 558
Contender 2574 |
I've actually sailed a tera, bic, taz topper oppie etc and i have to say i was very impressed by the tera. It has three sail options so you can progress she gets better heavier older etc. Plus a will plane with a lump like me in so it can't be all bad and most of the listed above, with the exception of the topper and splash which proberbly will (with enough breeze).
Edited by Smight at BBSC |
RS600 988
Simon Lovesey ![]() Far too distracted from work ![]() ![]() Joined: 30 Nov 04 Location: United Kingdom Online Status: Offline Posts: 349 |
The Mirror would make an excellent double handed option, particularly if your sister likes to sail in company, certainly a bit more sociable and many kids enjoy the confidence of having someone else in the boat. For your budget you will get a well sorted Mirror, epoxy coated so minimal maintenance. A bit more money will get a modern GRP Mirror. See
www.sailracer.org
Online Sailing Results, GPS Tracking & Event Management |
mattskipper14 ![]() Newbie ![]() Joined: 14 Aug 07 Online Status: Offline Posts: 6 |
MIRRORS ARE STABLE AND EASY TO DE-RIG OUT ON THE WATER, I HAVE A VERY OLD MIRROR (7041) THAT WAS MADE IN 1963 HOWEVER THEY ARE VERY DIFFICULT TO MAINTAIN AND QUITE HARD TO RIGHT AFTER CAPSIZE,A TOPPER IS PROBABLY BEST |
matt harrington
Topper, soo much fun when its really blowing!
Neil
Splash.
might be just on the light side right now. But she should try it. Designed as the next step after Optimists i.e 45kg crew weight. It's like a little laser with a single section tapered mast and full length top battern. Well mannered and easy to depower, with a more feel than you will get from toppers. www.splashdinghy.org.uk/ test sail details LINK second hand page LINK several to choose from around and under £1000 ![]() ![]() |
Fraggle ![]() Far too distracted from work ![]() ![]() Joined: 28 Feb 07 Location: United Kingdom Online Status: Offline Posts: 220 |
Topper would probably be best boat - great for messing about on and lots of them around with a good racing circuit if she gets into youth racing. They have a centre main available now too. (I am biased though as its what I started with many moons ago)
