Road Trailer Maintenance |
![]() ![]() ![]() ![]() Posted: 23 Jul 07 at 7:56pm |
Hiya,
After spending an hour going over the fireballs road trailer ... All I can say is "Damn, How did it survive Yarmouth to here! " Basically: Bearings are almost shot ( and have started disintegrating ) The shaft has a small patch of rust on it One axle has split for 6 inches of its legnth ( Yes, split! ) and looks like a bar of solid rust. Suspension is locked almost solid ( rusted I guess ) Poking the metal parts of the wheels was quite squishy .. Then I realised I was poking THROUGH rust into the innertubes! Now, The problem. I need the trailer done before fed week. Doesn't leave me much time. Can anyone recomend anywhere to go for axles and road wheels? I can fit it all myself, its just sourcing decent quality kit that won't rust the first time it crosses the bridge over to Hayling Island. ( I'm also on a stupidly tight budget ... so if anyone is scrapping an old road base - keep the axles + wheels for me!! ) Thanks Muchly! James |
TandyUK Servers |
My tip would be to not do it on the cheap. Go to Towsure and buy new suspension units complete with bearings and grease! I just bought a pair for a triple trailer and they were £75 for the pair. Wheels are only about £15 each so you can upgrade for about £100 Alternatively you can get second hand which may be as bad as the ones you take off. Old tyres are also usually perished - check the side walls. |
Bonnie Lass Contender 1764
JimC ![]() Really should get out more ![]() ![]() Joined: 17 May 04 Location: United Kingdom Online Status: Offline Posts: 6660 |
Its not cheap refurbishing a trailer... I had to do an old one of mine which was something like 100 quid, although that included getting an Engineering shop to make a custom acle...
Is there no one you can borrow a trailor from for the week??
Edited by Doug.H |
Gonna explore that avenue - But we will still need to get ours back to working condition so we can go play away from home.
Plus, of course, the stern supported trailers are rare .. meaning a higher resale value for the boat ![]() |
TandyUK Servers |
scottish_tornad ![]() Groupie ![]() ![]() Joined: 17 Apr 06 Location: Scotland Online Status: Offline Posts: 57 |
try here:- http://www.trailerpartswarehouse.co.uk/
bit cheaper than towsure and parts are just as good |
tornado GBR389
www.dalgetybaysc.org/home.htm |
