New Posts New Posts RSS Feed: Fittings - which are the best
 Post Reply Post Reply Page  123 7>
glewis View Drop Down
Post Options Post Options   Quote glewis Quote  Post ReplyReply Direct Link To This Post Topic: Fittings - which are the best
    Posted: 20 Jun 07 at 9:06am
Morning,
Friend of mine is buying a new Phantom and has the option of which type of fittings he can have - at a cost obviously.
So, which are the best nowadays, or are they all pretty much similar?
Giles
Solution 414
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 9:09am
Harken every time, although if you are on a budget Ronstan are next in line.
Never touch HOLT. Cheap, nasty and horrible and they dont last very long
jeffers View Drop Down
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 9:18am
I agree Harken or Ronstan, I would not touch Holt with a bargepole (had a Holt auto ratchet, it lasted 2 days then broke so i took it back for a refund).
timnoyce View Drop Down
Post Options Post Options   Quote timnoyce Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 9:36am
Not that I want to show any bias but there is a cracking video on the Harken site!
HERE
Crafty View Drop Down
Post Options Post Options   Quote Crafty Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 10:09am
I reckon that harken is the best,
just wondering what are your thoughts "fredirekson" , ive heard they do good racthet blocks
Laser Radial/4.7 144929
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 10:17am
I think there are good and bad fittings from all suppliers. I tend to mix and match. Ronstan seem a good compromise for price against durability for blocks. Holt's basic metal work is all plenty good enough and they have the best range, Harken don't have much of a choice in that area and are horribly expensive for what are basically strips of pressed steel. Holts blocks tend to be shortest lived, although their new range looks pretty neat and I have no long term experience of them.
combat wombat View Drop Down
Post Options Post Options   Quote combat wombat Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 10:31am
Holt aren't bad blocks despite what other people say.  I would fit my boat with Holt over Ronstan as they are crap.
On the B14 we have Holt autoratchets for the kite sheets, they are about 5 hard racing seasons old and still work just fine - and anyone who has sailed a B14 will know the kite sheet loads aren't insignificant.
Blocks just need maintenance ie lubrication occasionally and wash the salt out of them each time you come off the water.
Having said that, if I had the choice I would fit out a new boat in Harken throughout.  I've almost got rid of all the Ronstan rubbish on my boat although Ovi's insist on using it on their masts and booms.
B14 GBR 772
Scooby_simon View Drop Down
Post Options Post Options   Quote Scooby_simon Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 10:34am
Harken and Freds all he way
FireballNeil View Drop Down
Post Options Post Options   Quote FireballNeil Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 12:13pm
I sailed a 29er at the weekend with freddies instead of harkens which are what I am used to and they seemed really good, the non carbo harkens seem really heavy for no real reason, these freddies were quite old and had been used to death but the still seemed really good
gary View Drop Down
Post Options Post Options   Quote gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 07 at 12:22pm
Any of Harken/Holt/Ronstan/Freds should do the job. As combat wombat says its all about boat maintainance.
I've seen many a harken equipped boat retire due to gear failure when they're not looked after. I sailed a couple of seasons in a boat that was Holt throuout and never had a problem, BUT the owner was mad keen on boat maintainace - as soon as anything started showing signs of wear, of it didn't work quite right it was sorted out.
Its the same with my boat now, there's all sorts of different makes of fittings on there but it always gets checked over and de sanded/salted after use, then sorted out if its not right. We very rarely have any probems.
