RS 400 Help ! |
Page 123> |
headfry ![]() Far too distracted from work ![]() ![]() Joined: 15 Jul 04 Location: United Kingdom Online Status: Offline Posts: 359 |
![]() ![]() ![]() ![]() Posted: 18 Oct 04 at 2:32pm |
I need your help please I have been lucky enough to crew (racing) for a very, very experienced and capable gentleman. My problem is, apart from bucket loads of enthusiasm, i have no experince. I really dont want to let him down, as this is a dream come true for me, but i some need help please. Does any one know of a book or web site (RS 400 based ) where i can learn the ropes...literally! and the best methods for crewing the RS400 I know some will say get out there and do it!......I am! but I wish to contribute to the overall boat speed and not hinder it!! So please be gracious and offer a novice your views and help |
1. Go through the Yachts and Yachting subscribers articles to find general crewing
2. Read crewing to win by Andy Hemmings Fernhurst 1-898660-05-0 3. If you can get the videos: Better sailing and high performance sailing. Important issue: 1. good communication 2. downwind need to call the pressure on the spinnaker sheet. 3. more communication 4. move round the boat smoothly 5 communication Get the idea!!! Hope it works out OK Edited by Garry |
Garry
Here's a couple of tips for light to medium wind speeds. Don't sit on the thwart it puts your weight to far back and in the really light stuff a good place to put your weight, off wind, is sitting on the foredeck in front of the shrouds, you can play the gennaker from there. Try tacking facing aft, the sheets are much easier to grab and it keeps your weight forward.
Thanks folks, Valuable tips. I have the book 'crewing to win, however my need is great. I need to know what all those bits of string do! Here is a BIG ask.... what i really could do with is a diagram of the internal ( ropes, blocks etc) layout of the RS 400.
I can't find any pictures but I'll try and give you a verbal description. On top of the thwarts you have the jib sheets and on each gunwhale you have the gennaker sheets. I hope you know what to do with those, this leaves you only 2 more ropes the look after since things like rig tension, cunninham and kicker go back to the helm. On the floor each side of the mast and just behind it are 2 ropes. On the left is the pole outhaul (this is the thicker of the two) - pull on this and the pole shoots out in front of the boat and it cleats automatically. To the right is the gennaker haliard, so pull on that and the kite goes up - this also self cleats. Linking these two ropes is a strop made of a bit of thick rope or a bit of webbing, pull on that and both the pole and the spinnaker are uncleated. So apart from doing all the crewing type jobs like getting your weight in and out, operating the centreboard, telling your helm when the gust is going to hit and triming the jib and spinnaker, your other job is getting the pole out and the spinnaker up (in that order). Then when it come to dropping, pull on the strop grab the downhaul (just to the left of the mast and behind the block) and pull the kite down. This pulls the pole in as well. Use big arm movements and when it appears from under the foredeck, grab it and give it another big pull and stuff it back under the foredeck. Get sitting out with jib trimed properly and then grab the gennaker sheets and pull them into the cockpit and tidy up in rediness for the next hoist. They are fairly powerful boats so its important to get your weight in the right place and then tidy up, don't wait a bit to tidy and then sit out. Similarly at the windward mark don't be in a hurry to get in and get hoisting, keep your weight out to assist the bear away, then in for the pole and up with the kite. Your helm should be running very deep while you are doing that and then when its up he'll head high to "heat up" the boat which means you'll be sitting out hard. I always found them a very tiring boat since the crew has to sit out hard all the way up the beat and again all the way down to the leeward mark. During the gybe do not let the spinnaker sheet go loose but pull it in as you come in. Hit the new windward side at the same time as the helm stops the boom and then pull in on the new sheet. In this way the kite slips past the luff of the jib and doesn't get in a wineglass. Don't worry at all about the jib, just leave it losely cleated on either side to keep it from tangling with the gennaker. The helm can lean forward and sort the jib and he also operates the wing-wangs, you keep your eyes glued to the luff and the spinnaker as eased as possible but never let it collapse. He should now be telling you when the next gust is going to hit! If the wind is light keep your weight well forward (perhaps stand up at the base of the mast) and tell the helm when the sheet begins to go light - he should then "heat it up" a bit. These are fantastic boats to sail and when you think about it they are faster than a Fireball and yet don't have a trapeze. Only the B14 skiff is faster of all non trapeze boats. If you have a bit of weight and use it effectively you can plane to windward and yet such a powerful boat can still be handled in a 7 because the rig is so adjustable. Generally speaking (and I've said it before) you shouldn't sit on the twart its too far back and you should face aft when tacking. The only time you should face farward during a tack is at the windward mark where as soon as you've tacked you are going to go for a hoist. |
Wow Redback....... thanks thats great, I will read and learn. May I ask what you sail? and Where? Cheers from a grateful crew |
I sailed a 400 for a couple of years when they first came out, then a 800 when they first came out - in both cases as crew. Now I sail a Laser 4000 and generally helm it. I sail at Bough Beech SC near Edenbridge in Kent. |
Hi Redback, Have had a peep at your sailing clubs web site, what a nice place, and a very nice location too. do you have any web cams there? Thanks again for all your help Headfry |
headfry, tell us how you get on.
Morning Redback, Had a fab sail on Sunday in an F5!! Phew a touch hairy for a novice, but what magic fun.....need more of that please! That boat can sure get a tramp on with the spinnaker up....bit of a wild thing actually! Have now done about 4 hours as crew - still a long way to go but i am lov'in it Your help was just what i needed, gave me time to think things out during the week. Thanks agian -
Page 123> |
