TVR Paint job |
phantom871 ![]() Groupie ![]() ![]() Joined: 12 Apr 06 Location: United Kingdom Online Status: Offline Posts: 86 |
![]() ![]() ![]() ![]() Posted: 15 Jun 06 at 8:44am |
Do you think the wicked green fading to purple to silver TVRs paint is suitable for a boat Hull?
If its bent pull harder
NeilP ![]() Far too distracted from work ![]() ![]() Joined: 23 Nov 04 Location: United Kingdom Online Status: Offline Posts: 271 |
Yes is the simple answer! It's a pearlescent colour with what's known as a 'flip'. Mica flakes in the base coat cause the effect you are after. Even more dramatic effects can be got with holographic flake. It's a clear-over-base system, so quite a lot of paint has to go on, so would be quite heavy and expensive. The clear coat is 2-pack lacquer, so plenty durable enough. Been contemplating doing something like that with my Contender for a while now. Neil |
No FD? No Comment!
Depends whether weight is an issue... As neil says, its up to the job, but for a good quality finish you need LAYERS and by the time you have enough to get a decent quality finish its going to be very heavy
Unless you have access to the tools, ie, a spray room in a comercial garage, it's going to be a major hassle to do by yourself. Professionally, you are looking at the very minimum of £2k upwards for a boat builder to do it in basic colours, reckon closer to the region of £3k to £5k with that sort of paint scheme. Might be worth giving RMW a ring for advice, they might do it for a cost or give you the details of how to do it and take the list of how you want to do it and get a quote from your local garage's spray-shop but be ready for a few strange looks. "You mean to say that you want us to strip a boat and paint it?????
