Laser woes. |
Page 123> |
![]() ![]() ![]() ![]() Posted: 20 Apr 23 at 12:16pm |
Laser radial, sails well on starboard, move to port and speed drops right off, boat needs constant rudder to keep it in a straight line. Several people have tried it, does exactly the same?
Robert
I'd start by checking rudder in line? C/B in line? Mast post in line?
Peter
Not many options on a Laser... I'd try a different rudder and centreboard first as it should be easy enough to borrow one of each.
Laser mast rakes are all over the shop, stick a full rig bottom section in the hole and measure between the back of the bottom mast and the bottom of the transom lip in the middle, it should be 3815mm ish. Also check the distance from top of mast to each back corner and maybe some other point on either side to see if the mast pot is straight.
Turn boat upsidedown and fit centreboard and rudder, sight from front and rear and check that they are aligned.
One explanation I heard, there are steel rods in dagger board and it could be bent, never heard of this before.
Robert
How about sailing it backwards on port?
I'll get my coat...
Been backwards many times
Robert
There are certainly steel reinforcing rods in the board. The matrix is pretty brittle though, I'd be surprised if it could bend much, but warped daggerboard is the first thing that occurred to me with the symptoms. As well as trying someone else's foils in that boat try those foils in another boat.
I suppose with a gentle curve and the shape of the dagger board you would get unwanted lift, advantage one side to the other.
Edited by 423zero - 20 Apr 23 at 7:34pm |
Robert
Had another look, it appears the deck is detached from the hull on port side, I think the boat is actually distorting, you can easily push the hull inwards.
Foils looked ok when compared to others.
Robert
Page 123> |
