Transom flaps? |
Author | |||
![]() ![]() ![]() ![]() Posted: 24 May 22 at 1:26pm |
The transom flaps on my Scorpion are leaking, they are hinged carbon backed with pro-grip like P&B sell, they are pretty old and probably bent and misshapen so they no longer seal. What are people using these days?
Boats with double bottoms and open transoms? Sorry, couldn't resist it. The scorp I had back in the day was a great boat, like a puppy straining at the leash
mole ![]() Groupie ![]() Joined: 02 Feb 06 Location: United Kingdom Online Status: Offline Posts: 43 |
Bent and mis-shaped carbon?
It was either not a balance layup at manufacture or never carbon in the first place. I would replace with the same, except quality made version
sawman ![]() Far too distracted from work ![]() Joined: 04 May 11 Online Status: Offline Posts: 205 |
On scorp 1971, I have clear 2mm lexan for the flaps. the lexan was cut to shape at a local plastic sheet supplier to my pattern. They are secured with a shockcord "hinge" at the top. they are not secured with a line - the shockcord is tight enough to keep decent closure, but allows them to open if the boat needs emptying. However, I always tape up the bottom in light winds, as they will leak if going slowly and too much weight at the back of the boat
Haha good one, the RS200 I upgraded from had the same issue with shipping water in the transom as you sat with sails flapping on the start line! |
Thanks, I hadn't heard of lexan before but that looks good, do you know if it is possible to cut it yourself? I don't know of any local plastic sheet suppliers. |
I used old OHP film secured with clear tape across the top edge, with the tape overlapping the edges of the film to keep them closed. Water pressure was enough to distort the film for emptying. Dirt cheap and generally lasted a couple of seasons.
Nick
D-Zero 316 |
eric_c ![]() Far too distracted from work ![]() Joined: 21 Jan 18 Online Status: Offline Posts: 382 |
Lexan is a trade name for polycarbonate. I had 1mm polycarb sheet I think. Maybe thinner. It's what many motorbike visors are made from No hinge, it's just held by the pintle being bolted through it, it bends to let the water out.Thin shockcord to hold it closed, if the transom is flat and smooth it seals quite well.Maybe a 15mm overlap? People sell A4 sheets of it on ebay. Can be cut with a fine saw or abrasive disc in a dremeloid type of tool. Alterative, use some sort of tape or 'fablon', but of course be sure that you're not littering the water if you need the flaps to open.
yes you can cut it yourself, with a fine toothed saw, Lexan is a trade name for a polycarbonate, it is resistant to cracking when drilling, which not all polycarbonate is. You might find someone on line who would cut to your pattern - I happen to be near these guys. https://www.bayplastics.co.uk/ I think I sent them a template by email and collected a few days later - these sort of firms are great to use
