Foil Protection |
![]() ![]() ![]() ![]() Posted: 22 Dec 05 at 5:03pm |
Keep it up... we'll make a Development sailor of you yet! ![]() ![]() ![]() Edited by Jack Sparrow |
Most SMOD's ban any thing being added to the c.board in case it stiffens it or add's any advantageous (is that even a word!) properties.
-[Franko]-
That could be a good idea for the trailing edge of a Contender centreboard. It's really thin wood and gets easily dented by the trapeze hook, when righting the boat. Hmmmm, it's worth investigating..
Think most classes would probably have a law against this.But I may be wrong.Not sure it would help think it may even slow you down
This might be a daft idea (again), but I thought I'd seek opinion anyway. Has anyone tried covering their foils (or at least the leading edge) with a polyurethane film? This is a bit like the plastic sheets used to laminate paper and is commonly applied to cricket bats to prevent scratching and denting. Cricket, in turn, got the idea from helicopter rotor blades, which are covered in the stuff to prevent damage to the leading edges. It could even be used to cover the underside of hulls to prevent scratching. See 3M's site if you want more info. |
