New Posts New Posts RSS Feed: Autoratchet blocks
Autoratchet blocks
drifter View Drop Down
Post Options Post Options   Quote drifter Quote  Post ReplyReply Direct Link To This Post Topic: Autoratchet blocks
    Posted: 20 Jun 17 at 8:06pm
OK so I don't crew my Albacore, but my stand-in crew  (wife) last week pointed out that the Allen autoratchet jib blocks don't actually ratchet at all. I found a couple of others in the spares box, and they don't ratchet either.
Are these unusual, or is this a common problem?
£100 spent on Harken switchable blocks so I don't upset any more crews!
Stewart
Paramedic View Drop Down
Post Options Post Options   Quote Paramedic Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 17 at 9:56pm
If you send them back they will change them.
davidyacht View Drop Down
Post Options Post Options   Quote davidyacht Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 17 at 10:34pm
Like my Ronstan Orbit auto ratchet
Happily living in the past
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 17 at 12:09am
Sorry to be the bearer of bad news, but in my experience Harken don't deserve the good reputation they have.  I've had two Harken ratchets go in recent years.  Prefer Ronstan.
Post Options Post Options   Quote Paramedic Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 17 at 7:50am
Again, if you send them back they will change them.
I like the Ronstan ratchets i must admit, but I've had two of the new Harken 40mm autos as i think their tie solution will fit better around my existing fittings - we will see!
Harken are certainly not the runaway leaders that they used to be in terms of longevity, i think part of this is other manufacturers catching up the other part is the constant desire to make things lighter coming at a compromise.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 17 at 8:47am
Without wanting to state the obvious too blatantly, some auto ratchets have an adjustment for the load they kick in at, adjusted by turning them round the attachment point. Is it possible they just need adjusting?
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 17 at 7:59pm
OK 2129
RS200 411
RS400atC View Drop Down
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 17 at 8:58pm
It's also possible they just need cleaning. A good soak in hand-hot water may help.
fogliettaz View Drop Down
Post Options Post Options   Quote fogliettaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 17 at 8:17am
All blocks ratchet or free running and what ever brand should be hosed down with fresh water after use.
