New Posts New Posts RSS Feed: RS600 capsize righting problem
dohertpk View Drop Down
Post Options Post Options   Quote dohertpk Quote  Post ReplyReply Direct Link To This Post Topic: RS600 capsize righting problem
    Posted: 08 Apr 17 at 7:59pm
So I had a bit of problem getting the boat up after a capsize today. It was blowing 20 knots plus. The only way I could get the boat on its side from a turtle was with the rig upwind. I then proceeded to right the boat, allowing it to flip so the rig was downwind. However, before I could get on the board and right, the boat turtled again (I think it was the effect of the wind on the hull causing this). Has anyone ever had this problem? Is there a solution? Dare I say 'mast head float'?
< rel="async" ="commentable_item" method="post" -ft=""tn":""" ="https://www.facebook.com/ajax/ufi/modify.php" id="u_jsonp_17_1m" style="margin: 0px; padding: 0px;">
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 17 at 8:05pm
Most folks recommend an eskimo roll technique in that situation so you can get back quicker...
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 17 at 8:12pm
I had the same problem singlehanding my Spice in Holyhead bay. Masthead float is my solution though I did manage to recover the situation eventually by releasing the main halliard (having already released everything else, sheets, kicker etc.) and letting the mainsail fall to around half-mast. I then dropped it the rest of the way and sailed home under the jib. I now have a Blaze and having to deal with the same scenario does concern me so, if I'm alone and there is a prospect of F3+ I'll use a large masthead float.
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 17 at 9:37pm
On a 600 assuming you have a superspars mast, wrap self amalgamating tape around the mast head fitting leaving the smallest possible hole for the halyard to exit. It makes a huge difference to the bouyancy of the mast.
If the boat turtles, stand on the wing and sink it until you are up to your waist in the water then step onto the gunwhale to pull the boat onto its side. If its pointing the wrong way, get onto the board and lift the mast head just clear of the water. If it starts lifting too high, push it back down. You should be able to pump it around until its pointing towards the wind, then right it normally.
OK 2129
RS200 411
piglet View Drop Down
Post Options Post Options   Quote piglet Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 17 at 10:10pm
I was a bit light for my Contender so couldn't stop it flipping.
However I did get quite good at eskimo rolls, the trick was to pull myself round the board as I travelled underneath thus emerging on the top side of the board.
Do Different View Drop Down
Post Options Post Options   Quote Do Different Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 17 at 10:17pm
The bouncing and weathercock method although my Contender soft option is too slow for hard core serious racers. The cool crowd do the San Francisco roll, think I've read somewhere it is also favoured by Tasers, perhaps it's an Aussie thing.
Post Options Post Options   Quote dohertpk Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 17 at 10:21pm
Thanks all for that. I'm very familiar with the 'weather cock' method but I find it doesn't seem to work in breeze. That's a good tip about taping the mast though. Think it's time to start rolling...
davidyacht View Drop Down
Post Options Post Options   Quote davidyacht Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 17 at 8:17am
Agree with the San Francisco roll.
Also before you do anything try to dump the kicker.
Happily living in the past
jeffers View Drop Down
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 17 at 8:53am
I fund the blaze pretty well behaved on a capsize and it would come round in to the wind with a little persuasion .
The trick was to get round the front of the rack to do a 'dry' capsize though.
Cirrus View Drop Down
Post Options Post Options   Quote Cirrus Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 17 at 9:54am
https://www.youtube.com/watch?v=MNtpQW5HvaY
easy ..... why go in the water when your instincts are to grab onto those useful handholds ?
