Laser 161752 Tynemouth |
Best pump action Spinnaker halyard Cleat??? |
GG NHRC ![]() Newbie ![]() Joined: 12 Feb 17 Location: Lymington Online Status: Offline Posts: 38 |
![]() ![]() ![]() ![]() Posted: 09 Mar 17 at 9:49am |
Hi all
So what is the best pump action Spinnaker halyard Cleat??? And what are your views on the best system for hoist and drop??? |
Take a look at any Fireball, they have a pretty much standardised setup these days with elastic take ups.
You only need a drop if you have a chute.
IS this for a single hander or crewed boat? I came to like the Spinlock cleat for the hoist of the Alto, they fitted an RS700 style system to my V2 which worked really well, but it's a system involving rocker one way cleats and fairly complex system tuned by bungee which needs to be kept in good condition.
Simplest Hoist drop was the MPS, uncomplicated and once you got the knack of holding the tiller down on one knee was easy to operate. Worse system the RS100 which had gubbins up under the deck you can't get at and designed to fail only during a major event. |
Cheers guys
What would be really useful is any Fireball, 505, RS700 sailors opinions on which flip/flop pump cleat is the better option? There are a few options on the market, Allen, Northfix...??? Haven't seen the Spinlock one mentioned above, I'll do a search |
'Noah' who hangs around here has a pretty well set up Fireball, might be worth dropping him a private message in case he doesn;t see this.
I owned a 700 for 11 years and can confirm that the Northfix cleats are fine. Back in the early days (pre 2003) there were issues with the bases flexing so Northfix beefed then up. As far as I'm aware they are all at the new standard.
The cleats generally work fine regardless of rope type, but it's normally recommended if you go for a d12 halyard to bulk it out where it sits in the cam cleat. I had a full set of spares for my 700 but never used them, so 11 years of fairly hard use and the cleats were still in good condition. |
OK 2129
RS200 411 |
Great cheers...
Gee, thanks Jeffers. I don't think I've seen anything other than the Northfix on any Fireball, and it works just fine. Only issue I've ever had was the split ring working its way out, leading to loss of the pivot pin. (I hate tape!). Fixed by replacing the ring and squeezing it so it cannot rotate.
Nick
D-Zero 316 |
Thanks Noah
Much appreciated |
JohnJack ![]() Far too distracted from work ![]() Joined: 12 Mar 13 Online Status: Offline Posts: 246 |
I used to sail a Scorpion with bags. We had a Northfix with flip flops and a Harken Cam-Matic worked really well. Kite was up in a fraction of a second. You have to keep the friction in the system to a minimal as you have a 1:2 at the pump handle.
