winward boat after leeward boat tack |
laser161774 ![]() Newbie ![]() Joined: 08 Nov 15 Online Status: Offline Posts: 6 |
![]() ![]() ![]() ![]() Posted: 08 Nov 15 at 11:23pm |
Thank you, I am now a wiser sailer !
Brilliant forum I'll be back !
Seems I got it all wrong
Glad I did my turns!!! Thanks for all your help
Thanks I think his overlap was created in the tack as I sailed past not sure if he was clear astern.
Stevie_GTI ![]() Posting king ![]() Joined: 21 Oct 08 Online Status: Offline Posts: 134 |
for me if the leeward boats overlap was created from clear astern then they cannot sail above their proper course (which I am assuming is a close hauled course the same as yours), so therefore is in no right to luff you. Rule 17
My boat was further forward.
Thanks for your reply, Doesn't a boat that gains right of way have to initially give the other boat room to keep clear? Rule 15. |
When he completed his tack what were the positions of the boats relatively fore and aft. You say little or no overlap, but do you mean him on you, or you on him...which boat was further forward?
No, sounds like you've been out manouvred by a good sailor.
1st he didn't want you tacking off for whatever reason. 2nd he used leebow affect by tacking under and cranking it up 3rd He got you to do turns perfectly legitimately in my book.. |
Can anyone help? My first post. Today I was on port tack and realised I was give way boat to a boat on starboard, I left it as late as possible to tack, I was ready to go when the STBD boat tacked onto port. So I didn't alter course. By the time he had completed his tack he was about one boat width below me(I'm being generous here), with little or no overlap( I'm not sure which). He then called me up. At this point I looked back to see his bow overlapped I tried to point higher but I was at the limit. His bow was so close I could not tack without making contact. I complained "I have no room to manoeuver " he replied "windward boat" His bow then made contact with my STBD side about 1' from the transom. My thoughts; (1) I did not need to anticipate his pointing higher than me. (2) He did not give me room to manoeuver (3)He created his overlap less than two boat lengths below me so had no luffing rights. (4) He may have been the overtaking boat so (see Point No (3) (5) He made no attempt to avoid contact. Guess what I did my turns to keep the peace. Should I be aggrieved ? |
timbo laser
