Laser 161752 Tynemouth |
Snagging Tell-Tales |
![]() ![]() ![]() ![]() Posted: 05 Oct 15 at 12:39pm |
Just got a new set of sails with the proprietary red and blue tell-tales pre-applied, luckily in large numbers since at least half the time the yarns are snagged up on the (Mylar) sail seams and thus useless.
I've long been an advocate of putting silicone oil on tell-tales to stop them sticking when wet, but I don't see that helping here. The only idea that comes to mind is electrical tape over the seams, but it's a bit bodgy/temporary for a new sail! Anyone got any more elegant solutions?
Clear mylar sail repair tape that would be far better than electrical tape...
LASERNUT ![]() Groupie ![]() Joined: 12 Mar 09 Location: southampton Online Status: Offline Posts: 65 |
Coat the tail tell and area round the sail with candle wax
Sailmakers https://morgan-sails.com/
Learn to windsurf, race a bit, then you'll never have to look at them ever again. |
Change them for audio tape of you have any still in the loft.
Andy Mck
Thanks for the replies.
I considered cassette tape, but was reluctant to remove £10-worth of brand new posh tell-tales! The Mylar tape idea, Jim, sounds like a winner; can't imagine why I didn't come up with that one except I've never had any (apart from cheap stuff from B&Q that discolours and falls off almost instantly...) Not sure how seriously to treat the candle-wax suggestion - sounds like a good way of melting a hole in the sail - but if it could be done, remain flexible and not just flake off it could help. Maybe Nikwaxing the area would be a good idea, but more along the silicone oil lines, rather than stopping mechanical snagging - or how about using silicone sealant smoothed along the seams?
Just rub the candle on the area cold,you don't need to melt it
If the problem is mechanical snagging as described I'm not sure how much the candle wax will help outside the very short term.
Moral: keep the tell tales away from the seams, although that's easier said than done with some panel layouts. |
One contributor to the problem was that, as usual, the tell-tales were far longer than optimal for flow detection, and thus able to reach more seams than necessary.
I guess that's a consequence of the proprietary items needing to cover all boats from Oppies to Dragons and larger, but I always cut them down by about 1/3 with benefit. But this jib is indeed pretty complex in its panel layout. Off-topic, but has anyone else noticed that leach tell-tales (tell-tails?) applied to one side of the sail behave quite differently on one tack to the other? On one sail I had it could lead to huge undersheeting on one tack (before they'd fly) if you weren't careful. |
