New Posts New Posts RSS Feed: Whiffy Kit - The Pits
jaydub View Drop Down
Post Options Post Options   Quote jaydub Quote  Post ReplyReply Direct Link To This Post Topic: Whiffy Kit - The Pits
    Posted: 18 Sep 15 at 12:20am
My Gill Hydrophobe top has become a little too arm pitty for my liking.
It generally gets chucked in the washing machine on a quick 40 degree wash or a long 30 degree one with a small amount of detergent.  However that isn't making much difference
Is there anything that's worth trying to return it too it's former glory or is it a case of that's what happens with modern kit and it's time to replace?
If the latter, any recommendations?
The Hydrophobe was OK, but I prefer my NP equivalent (Thermalite).  Only problem with the NP top is it shrinks every time is washed, but does stretch back afterwards.
Any other options worth considering?  Don't like the Gul Evotherm, but Rooster Polypro and Magic Marine Bipoly are possibles.
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 15 at 8:35am
There is some enzyme stuff you can use which supposedly helps. Mirazyme, I think it is called.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 15 at 8:49am
Thing is the problem is basically caused by a population of bacteria, so washing at 30 degrees or even 40 degrees with small amounts of detergent isn't going to do much to kill them off.
about a boat View Drop Down
Post Options Post Options   Quote about  a boat Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 15 at 9:06am
Bacteria is the trouble. You can use a deodorant spray on the top. Deodorant “switches off” the smell the bacteria give off. Do not use anti-perspirent as this works in a different way and does not switch off the smell.
cad99uk View Drop Down
Post Options Post Options   Quote cad99uk Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 15 at 9:26am
Mcnett wet and dry suit shampoo or two caps of Dettol in a bucket of water.
transient View Drop Down
Post Options Post Options   Quote transient Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 15 at 10:19am
Diluted vinegar will kill the bacteria.....soak and rinse.
ChrisB14 View Drop Down
Post Options Post Options   Quote ChrisB14 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 15 at 10:33am
Simple solution: Anti-bacterial laundry cleanser (e.g. from Dettol). Add to the laundry, run at 30 or 40˚. Done. After two years our hydrophobs are still fresh. Even after getting a bit unpleasant over the course of a long event a single wash was sufficient to bring them right back.
B14 GBR 748 Bullet B
In build: Farr 3.7 GBR 410 (both sail number and the current number of loose parts)
Post Options Post Options   Quote jaydub Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 15 at 11:08am
Thanks all for your suggestions.
I'm running with Chris's suggestion of the Dettol anti bacterial laundry cleanser, although I can see the McNett's solution of wet suit shampoo plus a soaking in Mirazyme is probably the ultimate solution.
Loving the other suggestions, although slightly concerned that using vinegar (or mouthwash, which I've sen suggested elsewhere) might leave me with a different smelly problem. Wink
May well treat myself to an MM bipoly top anyway and take advantage of the 15% off Boat Show offer that finishes this weekend.
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 15 at 11:39am
If none of that works, it's best just to grab the top, bring it out to the garden and take the good christian dark ages approach of "Burn the witch!!".
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 15 at 12:17pm
Or just get a new crew with no sense of smell?
Peter
Ex Cont 707
Ex Laser 189635
DY 59
