Laser 161752 Tynemouth |
Small cleat raiser / standoff |
![]() ![]() ![]() ![]() Posted: 25 Aug 15 at 10:27pm |
nice idea but there is a rule concerning the position of the cleats. Basically they have to be near the cockpit due to the position of reinforcement under the deck.
RS300
I can see that the height of the racks dictate such a high riser in that location.
I understand that the action would be slightly changed but could the cleat on a less extreme riser be positioned closer to the mast where the line runs closer to the deck, perhaps with a fairlead some way forward of the cleat for more precise alinement. |
yes its the ones on the foredeck
I guess I could just get some ali box section I was just kinda hoping that some one would make something specifically for the job. Ian
RS300
Reasonably wide base though assuming its the one on the foredeck... In your place and if I were near someone appropriate I might try and blag a few inches of offcut carbon big boat mast or boom section as basis for a riser.
Edited by JimC - 25 Aug 15 at 11:18am |
Valid observation Jim and the answer is I'm not sure however the boat I have just sold had a hand made block with apparently just two holes and that worked brilliantly.
You can see what I mean in the film below https://youtu.be/rtJl9e9sz2c |
RS300
I don't recall seeing anything off the shelf.
Awful lot of leverage on that: whatever you end up with make sure it has a wide (long?) footprint. I think I'd want four fasteners with that, not just the two that hold the cleat down. I'd be tempted to make a little mould and fabricate a top hat section carbon bracket. Edited by JimC - 25 Aug 15 at 1:07am |
I want to raise a cleat by about 60-70mm
Any one know of anything this big for small cleats or do i have to make something? Ian
RS300
