Hull finish |
Splash II ![]() Newbie ![]() Joined: 22 Jul 15 Online Status: Offline Posts: 2 |
![]() ![]() ![]() ![]() Posted: 22 Jul 15 at 3:36pm |
Hi all,
What's peoples opinion on underwater hull finishes...??? I know all the arguments for and against polishing, high grade wet & dry, laminar flow over the surface etc. But in practice what do you feel is the best finish on a few years old GRP hull. Has anyone ever tried experimenting with some of the expensive automotive nano technology finishes to get an extremely smooth finish. I've seen the results of this type of finish and the water just beads and runs off very easily. |
My feeling is that the behaviour of droplets of water on a dry hull is pretty much irrelevant. It is underwater and will be wetted.
So just get it as smooth and fair as you can with the effort available. I suggest though you should be putting at least double the time into the foils as into the hull. This is especially true for pivoting board boats, where all too often that centreboard just stays in there accumulating gunge and gouges from one year to the next. |
Sanding chart on an old thread on SA here:
http://forums.sailinganarchy.com/index.php?showtopic=84231#entry2068554
I'm a fan of polish on a 1200 grit sanded hull. Mainly I like how easily it slides onto the trolley after sailing, and in my head it is fast, which is what matters.
Bit of a fan of a good soapy wash to get off the crud ... Then polish with Hullcote.
Wet and dry finish on foils, something around 800 seems fine to me. IMO don't want them too polished as I think this encourages separation, besides which too shiny when you tip it in. As Jim said, time spent on leading edges and trailing edges of foils is well spent. Also transom edges and slot gaskets warrant a bit of care. Those who's formative reading was Elvstrom Speaks (should be on any bodies reading list) may remember Elvstrom talking about crud making a discernible difference to performance.
Happily living in the past
Rudders mirror finish if you can manage it. That would be good for centreboards too if you didn't have to stand on them to right the boat.
