Laser 161752 Tynemouth |
Hard Chine or round bilge? |
![]() ![]() ![]() ![]() Posted: 31 Dec 14 at 9:36am |
I'm redrawing some Canoe lines at the moment which some day will make to to the Canoe website, so I've got a variety of old documents scattered round the PC.
It used too be quite a big discussion point: this is a quote from an early 50s Yachting World I think:
Redrawing the old lines, which were of Eastwind, an Austin Farrar Canoe, very Uffa Fox influenced and pre-war looking, and of Conquest, an early hard chine Jack Holt design, I was struck by how very hard chine Conquest is, with no curvature in the sections at all, and how very rounded Eastwind was... And it occurred to me that, in these days where we actually seem to have something approaching a consensus in mainstream deign, what we actually have is something in between, since although the typical contemporary boat has a single chine, the rest of the shape has curved sections, often as curved as anything that would have been seen on an old round bilge boat. So hard chine versus round bilge? Neither - or both. Its funny how often that plays out, time and time again in history it seems that there must be a decision between x and y, but in the end, when the shouting has died down, the grand controversy just fizzles out... |
Yup, round bilge for less wetted surface, with those chines at the back to make for more stable planing. We are almost back to arc bottomed sharpies of the late 19th century.
You can have chines that aren't immersed that mean that the topside can be single plane curvature - this is a build friendliness gain on boats of any speed.
Immersed chines (and this can depend on trim and heel) have a crossover at fn=1 (12 kts for a 14ft dinghy) - below which they are disadvantageous, above which they aid lift and reduce drag. Curvature, transverse but particularly f/a in the aft half of a hull should be minimised in a boat spending most of its time semi planing ie 6 to 12 kts for a 14ft dinghy. This will, however generally be at the expense of wetted area and result in more transom and forefoot immersion, both of which are killers sub kts. As with all things it's about compromise. Chines can be used on any dinghy, but generally should only be intended to make contact with the water in the aft third of the boat with stern trim ie when going fast. Similarly, rounder sections fwd will mean that wetted surface can be optimised with bow down trim in the light, with flatter and straighter sections aft for dinghies with high speed potential. Of course then you also have to think about stability/ wetness / motions in sea |
I don't know how dfferently a Canoe should be viewed, it sits in its own domain between catamaran design and most monohulls, being somewhere between the two in length/beam and length/mass.
In light airs, surface area rules, so a narrow rounded hull wins. Cats of course don't need form stability but a monohull designed to absolute minimum wetted area would be a bit of a handful I think.... Early planing needs flat sections at the back, rounded hull forms often work well because there are no chines to dig in and work against the foils by steering the boat. At speed, chines help stability, when did you last see a round bilge powerboat? But in light airs, flat water, they're out of the water on many boats. The subtlety of marginal planing, or upwind in chop, or quick tacking or reaching through big waves is much harder to analyse. Then you have to think about making it easy to get it around the course when it's really too windy to be worried about optimal drag.... In my limited view, there is something about 505's and some Merlins which helps them keep going when other boats are capsizing, even if I'm driving. How do you analyse being half-flattened by a gust in Solent wind-over-tide and riding out of it? |
"Like" all the above comments.
But what about the Scorpion? Not light, not long, not much righting moment or white sail area, fair bit of keel rocker, but - it seems to me at least - always unexpectedly quick in both light and stronger winds. The chines are very straight, and contrary to popular concepts extend right to the bow where I guess they release spray/bow-wave water earlier from the hull than would otherwise be the case.
