New Posts New Posts RSS Feed: Topper dinghies...
Topper dinghies...
RichTea View Drop Down
Post Options Post Options   Quote RichTea Quote  Post ReplyReply Direct Link To This Post Topic: Topper dinghies...
    Posted: 14 Dec 14 at 8:02pm
Those that know about toppers, what does the patchy faded sections on this topper indicate:
This picture it is on the port side near the transom
on the second picture it is over the front and also a patch by the mast section. I am looking at them on behalf of a parent but cant answer her question so am calling on you lot!
Edited by RichTea - 14 Dec 14 at 8:03pm
RS200
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 14 at 8:32pm
Looks to me like there have been impacts there at some time. No real idea if they matter or not - worth pushing on the bit on the foredeck perhaps and seeing if it's soft or deformed? Not much you can do really whatever it is!
Peter
Ex Cont 707
Ex Laser 189635
DY 59
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 14 at 8:49pm
Or it could just have been left for an extended period with a cover with holes in...
laser193713 View Drop Down
Post Options Post Options   Quote laser193713 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 14 at 8:51pm
Or scuffs from the cover that have become a bit more uv sensitive? Could have had some wet kit left under the cover perhaps.
jharvey View Drop Down
Post Options Post Options   Quote jharvey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 14 at 8:55pm
Sailing Solutions have an article about dealing with faded decks and bruising.
http://www.sailing-solutions.co.uk/blog/deck-colours-and-repairs
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 14 at 9:06pm
They are pressure marks. The one that would worry me is the one at the corner of the mast gate where I suspect a screw has been over tightened.  I would want to know that this hasn't caused a crack that then leaks into the hull.  As for the ones on the gunnel, look underneath and see if there is a crack there or if the deck and hull have separated at all.  Those again can be points where the boat can leak.  The discolouration on the foredeck is the least of your worries, provided there is no cracking.  Colour can be restored through judicious use of a heat gun.
Post Options Post Options   Quote RichTea Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 14 at 9:23pm
Thanks all, very helpful.
RS200
piglet View Drop Down
Post Options Post Options   Quote piglet Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 14 at 10:28pm
I tried a heatgun on a red hull but the result was patchy and inconsistant so I gave up.
The marks on the gunwale near the transom look like collision bruising. The fordeck marks could just be fading patches.
If it holds air I wouldn't worry.
Why do the red ones fade in a circular patch on the fordeck?
