Laser hull discolouration |
Page 123> |
StevieDexter ![]() Newbie ![]() Joined: 11 Nov 14 Location: United Kingdom Online Status: Offline Posts: 6 |
![]() ![]() ![]() ![]() Posted: 11 Nov 14 at 7:48pm |
Hi
I've bought a second hand Laser and the previous owner had some horrible 'ANIMAL' brand decals on the bow. I've carefully removed these but where they have been on there for so long they have bleached the hull and left a nasty off white version of the decal design. What steps can I take to try and get rid of these? Can it be cleaned or will I have to re-coat the whole hull? Thanks in advance Steve
Have you tried rubbing compounds? T Cut, maybe, though I'm sure someone can remember a brand more suited to GRP. Faracla make some, I know.
Thanks Rupert
No I haven't. After I posted this I read something about using 600 wet and dry to rub it down but not sure what I'd finish the job with after that. Maybe T Cut...
I'd start with the T cut and avoid the wet and dry unless totally desperate.
failing that, just put a bigger sticker over it of a brand you like.
When i cleaned my Laser hull up prior to selling it I gave it an all over t-cut (to get rid of the brown 'tide mark' that the hulls seem to develop). Took me a couple of hours all told but the boat looked very shiny and the new owner was impressed when he looked round it.
I would avoid wet and dry, this is just too abrasive IMO unless you are trying to get rid of scratches.
Edited by jeffers - 13 Nov 14 at 4:46pm |
Try T-cut first, but the abrasive in T-cut is very fine and may not dig deep enough to remove the discoloured surface layer.
Next step would be to get your hands on some Farecla G3 or 3m perfect-it 09374. Wet & dry would cut the surface off but 600 is very fierce, 2000 or 1200 at the most, use wet on a soft block (eg. polystyrene) and don't waste time with knackered paper, it's a consumeable! Edited by piglet - 14 Nov 14 at 3:20pm |
I was told by one who claimed to know, that if you waxed your hull with silicone car wax, it wouldn't fade. Tried it on my blue above the waterline L3k and it didn't fade, but it might not have anyway.
Can anyone conform or deny?
I believe there are car waxes that have a UV filtering capability, and that ought to reduce fading.
Page 123> |
