RS600: separating seized mast |
![]() ![]() ![]() ![]() Posted: 20 Aug 14 at 7:15pm |
Hi all,
Has anyone any experience with separating an RS600 mast? The previous owner didn't use the reefing system at all so I think it's been ages since it's been separated. Is this a lost cause? Would like to be able to sail in more wind... Cheers, Peter
simsy ![]() Posting king ![]() Joined: 14 Jun 05 Location: United Kingdom Online Status: Offline Posts: 158 |
I may be thinking of a different story but I think I remember somebody telling me they used their car tethered to one end of the mast and the mast attached to a suitable fixed object, to separate.
I won't be held responsible for being wrong though.
Crikey. That sounds like a recipe for an exploding few feet of carbon and/or a shattered rear window. There has to be a less risky way, no?
Also, I don't a car. Is there any alternative method?
Go on the RS 600 yahoo group, there will be loads of people who have done it: there is all sorts of advice including using heat and ice. personally I have separated a number of RS100 masts and I just alternated water from a hose from each end of the mast, with WD40 and bending the mast at the joint while you do it. When we came back from the 100 nationals at Parkstone we brought back a 100 mast from the IOM that 6 people had tried to pull apart by force, and me and the Saturday girl separated it over the course of the morning by just gently keeping on at it as above- we didn't get frustrated or annoyed, we didn't butcher it and we didn't give up, in the end it came apart quite easily! It is only microscopic bits of sand and mud jamming it usually so just persevere.
Thanks for that Rob - having trouble accessing the RS 600 yahoo group. Flushing it out is a good idea, although I've read elsewhere that WD40 is bad for carbon (correct me if I'm wrong!). I just need to separate the mast for reefing. Is there any reason I can't simply zip up the sail and use it on the full length mast? I know I'd have a big gap between the boom and the sail, but is there any reason it wouldn't be sailable?
Trouble with the old 600 masts RS in their wisdom used an alloy stump and there is a reaction between carbon and ally and the stumps fused to the masts making separation very difficult.
These days they have learnt and the stumps are carbon. Separation is a mix of hot and cold water lube and pulling and flexing. Good luck. |
That was only the elliptical shaped angel masts with the aluminium sleeve - all the superspars ones had a carbon sleeve. If its an angel mast then leave it. For the superspars mast then use the holes in the mast for the boom bolt and rope through there and the halyard at the other end - couple of ratchet straps to something very immovable and gently tap the side of the section with a piece of wood and it should come apart slowly. Once apart clean all the grit out - give the mast a good flush and i always used Vaseline on the joint and took it apart every few months even though i didn't reef it in 3 years.
Edited by Neptune - 21 Aug 14 at 8:52am |
Musto Skiff and Solo sailor
MattK ![]() Far too distracted from work ![]() ![]() Joined: 02 Feb 05 Location: United Kingdom Online Status: Offline Posts: 221 |
![]() Concrete Block ![]() Forklift ![]() Drive the forklift away from the concrete block ![]() Success
Edited by MattK - 21 Aug 14 at 11:06am |
I seem to recognise some of those people...
