A few thoughts on bandits |
Page 123 9> |
fish n ships ![]() Groupie ![]() ![]() Joined: 11 Jul 14 Online Status: Offline Posts: 71 |
![]() ![]() ![]() ![]() Posted: 31 Jul 14 at 2:39pm |
Ok, now i know that several of you read the title and thought "oh no not this again" - to clarify i'm not interested on listing which boats are bandits, why their PY is wrong, what should be done about PY's, moans about being beaten by bandits etc, etc....
I sail a Phantom and last night in a F3-5 screamed around the course and won on handicap, to a few friendly digs about bandits. We talked through the evenings sail in the bar and how everyone had been struggling with the high wind start, lull to a F3 in the middle and then back up to a F5/6 finish (it was an hour long average lap race). It was only driving home that i had a thought that made me think about "bandit" boats. Basically it boils down to the fact that last night i wasn't struggling. When we set off in a F5 i dropped my rig back into powered conditions, tensioned up the lowers added a load of kicker and went sailing. The wind dropped halfway through so I reset my rig to searching for power (more stood up and more rig tension). As it picked up at the end i subsequently dropped it to overpowered (rig tension very low, kicker to leave the boom end an inch above the back of the boat). I'm not saying i wasn't hiking hard (my legs this morning were like jelly) but i wasn't fighting the boat/conditions/lack of fitness and at no point did i think i was going to capsize. This is the greatest thing i've found since buying the Phantom; I always feel in control but from discussions with everyone else they were mostly struggling with too much wind then not enough then too much again. I know that Merlin rockets (another so called bandit) are also fully adjustable and seem to go out no matter what the weather. So my point about bandits is this, is it more than these boats are much more adjustable to the wind conditions allowing them to sail competitively in a much wider wind range. In this respect rather than these boats being bandits is it not that other boats maybe just have a more limited optimum range of conditions? This would explain why on handicap they are seen as performing above their number as they are not limited to the "well it was xx class weather/course today so i ddin't stand a chance" as they can be adjusted to suit many more conditions. I know its very likely to be me spouting rubbish but thought it may be worth hearing a few more opinions from the vast wealth of 'knowledge' in the forum. Edited by fish n ships - 31 Jul 14 at 2:40pm |
I think you have a point- of course it does rely on knowing how to set the rig up properly, and how to change gears properly around the course. Not my cup of tea personally- I prefer simpler, unstayed rigs these days.
Fish n ships
certainly we've found boats that only race in their ideal conditions will eventually return a number that makes them hard to win in their favorite conditions and potentially at one end of the wind spectrum a bandit and at the other end an absolute dog. All this of course depends on the class of boat and the mentality of the sailors in that class and what conditions they prefer. I always try encourage people who are on adjusted numbers that are worried about it to race in all sail-able conditions and encourage your fellow class mates to do the same, that way if everyone does that you get the best average, hopefully leaving the best sailor as the winner. The only assumption is that all classes have the same depth of talent from front to back of fleet.
Back about 1960, when terylene sails came out, our grandfathers found the change so compelling that they issued what was effectively a new set of PY numbers, with some classes not changing, most coming down around 30 points in rough modern equivalence, and some as much as
50. I'm beginning to suspect that something in the epoxy foam hull/carbon spar/laminate sail changes may have been equally significant, because otherwise I'm at a loss to explain some of the changes we've seen. Trouble is none of those three looked that big a deal when they appeared in the true development classes. Also there are the practicalities. terylene sails were an easy spot. I suspect that if clubs had been asked to record all three changes and provide a separate return for all the possible combinations the results would not have been satisfactory. But on the original point, in the new web system increased adaptability will simply be reflected in the number that's spat out. Edited by JimC - 31 Jul 14 at 3:48pm |
I appreciate that the numbers will change with time which seems fair to me. I was just wondering more as to the why these certain boats seem so quick in most conditions to earn the bandit monicker. Its interesting you mention the three elements of carbon spars/frp/plastic sails could it be that rather than making a boat fast they just make everything easier which has an side effect of the boats able to be sailed faster? I know that having a well sorted boat makes things much easier and allows the boat to be sailed easier - something i find entertaining when people complain about being beaten by bandits. When you ask why they looked to be sailing with no kicker, outhaul or cunningham and get a reply of "well the kicker was on fully, the outhaul is so stiff i can't pull it on and i don't have a cunningham..." |
There's definitely something odd going on. Our top Laser sailors are having trouble beating top Solos on elapsed time, and one of our top Lasers has given in and bought a fairly new Solo and is immediately doing far better in handicap races. When he has some more races under his belt I shall have spme very useful data points. And Solos don't even have plastic sticks.
On the other point, sure some boats are far better set up with better controls than others. In an observed performance system like PY this will simply be reflected in the handicap, so it doesn't matter. Edited by JimC - 31 Jul 14 at 6:17pm |
Adjustability didn't seem to 'benefit' (i.e. reduce) the Laser PY when the XD kit was introduced, did it? At least, I can only ever recall the Laser PY going up.
Jim, I have sailed Solos for the past six or seven years, I can attest that the current rigs are considerably more useable across the range than back then. Also the FRP boats that became available 8 or 9 years ago are much more ergonomic than the wooden boats of the past, therefore easier to sail to potential.
Back in the eighties I borrowed a world championship winning Solo and in a breeze you approached a run with trepidation because everything was so twitchy, with modern shapes, stiffer boats and much more solid rudders things are more in control. Finally, Solos are one of the hot classes of the moment, plenty of Solo sailors are sailing better because they are often One Design racing against very good sailors, which raises their game. Also the fast settings and support from professionals is freely available, again improving individual sailors performance. So even though I sail one, I would accept that in certain conditions a Solo is a (slight) bandit, however I would suggest that your Laser sailor would regret his decision if you had a series with lots of reaching in marginal planing conditions.
Jeepers ![]() Posting king ![]() Joined: 26 May 11 Location: Hamphire Online Status: Offline Posts: 147 |
Or could it be that the "talent differential" is greater in these bandit classes ie the best sailing talent in the class is significantly greater than the average sailor (on which the PN is supposed to be based). So good+ sailors in the class will find it increasingly easy to outperform its PN.
NickM ![]() Far too distracted from work ![]() Joined: 27 May 09 Location: United Kingdom Online Status: Offline Posts: 328 |
Good point Jeepers. I think the talent (or if you prefer, speed) range in the Solo Class is huge because many Club sailors are still using relatively uncompetitive old wooden boats.
Page 123 9> |
