Righting moment question- expertise required |
flano ![]() Groupie ![]() Joined: 06 Aug 05 Location: Australia Online Status: Offline Posts: 46 |
![]() ![]() ![]() ![]() Posted: 21 Jun 14 at 4:15pm |
Please help
I'm currently sailing a 16ft skiff, which a lot of you guys would probably not be that familiar with. Class rules specify 3 crew but only 2on trapeze. My current crew consists of myself, skipper, hiking at about 75kg at 6ft6". On traps my sheethand is a big bopper at about 115kg and 6ft 3" with my f'hand around 5ft 10" and 70kg. My question is, if I decided to start steering from the wire and swapped my f'hand with a 40kg kid who would now take up the hiking role on the boat, potentially how much righting moment would I be likely to lose? The goal would be to obviously drop 30kg out of the boat without compromising our righting moment too greatly. To work it out accurately I imagine you would need to know the width of the boat which is close enough to 1.8mt. The ultimate goal would be to give the 16ft skiff national titles a real shake. Anyone that can give me some solid feedback on this will get a significant thanks in my acceptance speech after taking the crown. Also be welcome for a beer at my place whenever visiting our tops sailing Mecca in Belmont, Australia.
Thought I'd add a photo just to give you a bit more to work with ![]() |
I get 5094Nm at current config, 4922Nm if you get the kid hiking (assuming a 40kg kid is 1.5m and hikes pretty hard) so 3.5% RM loss which is fairly minimal tbh. Don't know lightship for a 16, lets assume 130kg giving 400kg sailing displ in current trim - you can extremely crudely assume resistance is proportional to displ, so you will lose 8% of displ.
I reckon that would help esp in a lighter series, assuming the kid can hike / trim / take abuse / hand out the beers / manage all the fishing tackle :-) Looking fwd to redeeming by beer. |
Daniel, your a legend. Exactly the type of info I was after. Probably should have mentioned that crew work is likely to take a significant hit as well. So any change would need to see a substantial improvement in straight line speed to overcome a slight loss in going round the corners.
Not sure on overall weight of the boat when it hits the water. Hull weight is about 74kg with all fittings. Mast around 15kg, boom 3 or 4kg + the rest I'd assume we'd be close to 100kgs all up.
Cool. Well a good I14 is 100kg when it hits the water (measurement scope is ex mast, boom, foils, sails etc) and I assumed there would be a bit more boat with the 16 - built in wings, more surface area etc.
All the best with it! |
The answer wouldn't be that hard to work out - though having the kid's height would help (makes less difference hiking that trapezing, but it's still relevant.
But all anyone could come up with as a number would be something like the % loss of righting moment. To convert from that to would it improve your chances of winning would depend on a lot of other factors - how windy will the races be not being the least. Are you generally overpowered, or underpowered? My advice would be give it a go, and if you could do it with another boat to sail against so much the better. For what it's worth, making some simple assumptions, I reckon your total crew righting moment is going to be be reduced from something like 406 kgm to 391kgm, while total boat mass goes down by 30kg. So not a large drop. A definite winner in light wind (if the kid is as good a foredeck hand!), might cost a bit in strong winds though? Whatever you do don't sack the sheet hand - he makes up more than 50% of the crew righting moment!
Peter
Don't worry, I won't be sacking the sheethand, look at the size of him. Not the sort of bloke you want to get offside
I'm amazed you can get down to 75kg at 6'6". I would consider myself a slim 6'6" and come at 97kgs. If I could get near your weight I might even be able to try a moth....10 years of trying suggest this will remain a dream....
Pretty sure Giles Scott is 6'6" and must be about 97 kg, and looks pretty slender.
Edit - he was low 80s at that height in his laser days and was a beanpole! Edited by Daniel Holman - 21 Jun 14 at 7:30pm |
