New Posts New Posts RSS Feed: Laser Rainbow
Laser Rainbow
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Topic: Laser Rainbow
    Posted: 21 Apr 14 at 5:31pm
This boat was bought by a friend at Whitefriars. It was a new one on me. When they lost the rights, Laser had 15 Tasar hulls left, so they put a less powerful sail on and called it the Laser Rainbow, apparently! Still had a Tasar insignia on, though.
Anyone know any more about it? This one is No 3.
Er-Indoors View Drop Down
Post Options Post Options   Quote Er-Indoors Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 14 at 6:53pm
Well you're not going to lose that in the fog!
Lightning 418 "Octarine"
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 14 at 7:26pm
The person to ask is webmuppet, though he doesn't come this way much anymore.  He has two modified laser runs.
mongrel View Drop Down
Post Options Post Options   Quote mongrel Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 14 at 8:20pm
I don't know if its true, but I'd heard these rainbow boats were a basic fibreglass lay up, without any foam sandwich.  The Tasar is fully foam sandwich so in theory is quite a bit lighter and stiffer than the Rainbow.
lionel rigby View Drop Down
Post Options Post Options   Quote lionel rigby Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 14 at 12:59pm
The Tasar rainbow as it was known was produced by Matthew Wetz, quite a few years ago when he took over the UK agency for the Tasar. Matthew wanted to produce a much cheaper and simpler version of the Tasar with the hope of selling it to sailing schools. It was indeed as previously mentioned a fibre glass lay up so was not as stiff nor as light as a Tasar but cheaper to produce. The Tasar has a 2 piece winged shape, rotating mast, with adjustable diamonds and with fore and aft adjustable shroud plates, adjustable jib cleats, and a curved traveller. The Rainbow had an ordinary, non rotating alloy mast, simpler boom without the controls, fixed jib cleats and fixed shrouds and a straight thwart. The Rainbow never caught on and died a death. It can not even be converted to a Tasar spec as though the hull shape is the same the construction is different and the cost of obtaining and fitting all the necessary parts would be rather prohibitive.
Golden Oldie
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 14 at 2:01pm
Many thanks - I shall pass this info on at the weekend.
Post Options Post Options   Quote lionel rigby Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 14 at 5:55pm
One other thing Rupert. The Tasar at that time had Dacron sails and no forestay. The main was fully battened and the jib could be furled using the furling devices on the bow and mast. Looking at the picture it appears that the thwart is curved but whether the traveller rail could be fitted isn't clear.
Golden Oldie
Gfinch View Drop Down
Post Options Post Options   Quote Gfinch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 14 at 5:08pm
I saw this boat in November, from what I heard they tried to turn it more into a cruiser than a racer, with a furling jib e.t.c.
N.B. I was told 5 were built or still around. Definitely a rare one!
3513, 3551 - National 12
136069 - Laser
32541 - Mirror
4501 - Laser 4000
