New Posts New Posts RSS Feed: Centreboard missing tip
hobbiteater View Drop Down
Post Options Post Options   Quote hobbiteater Quote  Post ReplyReply Direct Link To This Post Topic: Centreboard missing tip
    Posted: 31 Oct 13 at 12:31pm
the tip of my RS centreboard is missing, about 25mm.
How do i fix it?
hollandsd View Drop Down
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 12:55pm
any photos?
Dan
Laser 184084
Tasar 3501
RS600 698
RS600 782
Post Options Post Options   Quote hobbiteater Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 1:00pm
Edited by hobbiteater - 31 Oct 13 at 1:06pm
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 1:07pm
Has the outer laminate detached from the foam core at the top of the image?
do you want to know how to to a cosmetic repair or a purely functional one
Dan
Edited by hollandsd - 31 Oct 13 at 1:07pm
Laser 184084
Tasar 3501
RS600 698
RS600 782
Post Options Post Options   Quote hobbiteater Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 1:14pm
yes its has. also most foam is missing behind the tongue of glass from about a span wise position of the v towards the tip. photo doesn't show it too well and the photo also masks how much is missing and its faired in, but the curve steepens quite dramatically whereas it should be constant radius.
although i can contrive to capsize at any time the board is mostly under water so a functional repair is fine, but a solid one.
thanks
tgruitt View Drop Down
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 1:41pm
Post Options Post Options   Quote hollandsd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 4:01pm
1)I would use west 404 high density filler with west epoxy to adhere whatever is loose back together with clamps.
2) Use a grinding disk on a dremel and cut a slot front to back in the tip of the foil.
3) Get some solid glassfibre sheet and use an epoxy/404 mix to glue it in place then cut it to rough shape.
4) Fill one side with 404/epoxy.
5) Fill other side.
6) Sand away.
7) Add more epoxy filler mix
8) More sanding.
Repeat untill you have the shape of your foil right.
Dan
Laser 184084
Tasar 3501
RS600 698
RS600 782
Post Options Post Options   Quote hobbiteater Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 6:28pm
Thanks v much dan. I was considering v11 as a filler, I take it epoxy +404 is better. Plan was like tom's video, but like your method much more.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 13 at 8:29pm
To be quite honest, if its not a very bad bash, I sometimes just get ordinary shop araldite out and build it back with that. Its got too much silica in for ordinary filling tasks but for a board tip that you'll probably bash again its awfully convenient.
catmandoo View Drop Down
Post Options Post Options   Quote catmandoo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 13 at 9:22am
Epoxy putty is your friend and ideal for this scenario ,
First though you have to adhere loose outer lamination as above ,
Then you need something to stick onto , either a fillet of glass fibre as above , brass panel pins , or as i used last time some ss pins made from left over end of ss welding rod ,
Epoxy putty easily available , comes in a stick like rock with hardner and filler together but not mixed , you break a bit off squeeze it about in your fingers , then put into place and mould with your fingers , it has consistancy of plastacene , very quick and easy ,sets in minutes, when initially first set tiime to give the final quick sand , it then goes on to set absolutely rock hard.
Ive fixed leading edges without oins , tips to wings on my rudders , centreboard  tips , trailing edges , all proved test of time , if you are only filling and not glueing can be done inbetween races !!! Or even on the water as it can be applied to wet surfaces .
Edited by catmandoo - 01 Nov 13 at 9:24am
