New Posts New Posts RSS Feed: burgee clip fitting
burgee clip fitting
pjds196 View Drop Down
Post Options Post Options   Quote pjds196 Quote  Post ReplyReply Direct Link To This Post Topic: burgee clip fitting
    Posted: 19 Jun 13 at 2:16pm
as simple as drill and rivet?
what can i drill into at the top of the mast? where should i put the clip?
ta
Pete
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 2:40pm
plastic, tin or wood spar?
Post Options Post Options   Quote pjds196 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 2:50pm
rs400 - ally
RS400atC View Drop Down
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 3:09pm
what can i drill into at the top of the mast?.....
Pete
Try to avoid the halyard....
Both with the drill and also in terms of the halyard rubbing on screws or rivets.
You only need a couple of small fasteners, the metal is relatively thick, so small self tappers or even M3 or M4 tapped holes will work.
It's probably prefereable to drill in the side of the mast, not the weld?
MerlinMags View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 3:55pm
Or there's the old skool trick of bolting to the mainsail headboard, which means you never forget to put the burgee in before stepping the mast!
Lukepiewalker View Drop Down
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 4:03pm
It does introduce the old school trick of getting the halyard wrapped around it when you aren't paying attention and crushing the burgee though...
Ex-Finn GBR533 "Pie Hard"
ex laser View Drop Down
Post Options Post Options   Quote ex laser Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 4:43pm
whats the best way with a carbon mast? any ideas welcome.
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 6:46pm
Glue! If you can, never drill holes in carbon.
alstorer View Drop Down
Post Options Post Options   Quote alstorer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 13 at 9:06pm
having said that, if you've not got a mast head kite, the top 10cm of the leading edge of the mast is likely taking almost no load at all of any sort...
Al
