Is Carbon good for mast struts? |
![]() ![]() ![]() ![]() Posted: 24 Apr 13 at 9:30am |
depend if your trapezing and don't let go when you miss the hook....funny how for the first couple of times your mind thinks keeping hold is a good thing!
Musto Skiff and Solo sailor
Thunder Road ![]() Far too distracted from work ![]() Joined: 24 Jun 10 Location: United Kingdom Online Status: Offline Posts: 372 |
Finn GBR16 Thunder Road.
Mike Holt ![]() Groupie ![]() Joined: 29 Nov 09 Location: United States Online Status: Offline Posts: 58 |
Been using carbon ones on 505's for years. No problem using them, but more because they look good than any advantage.
AlanH ![]() Groupie ![]() Joined: 17 Apr 10 Location: Scotland Online Status: Offline Posts: 84 |
Thanks for input guys. I had a feeling there might be some downside, and getting battered by a metal clew doesn't sound nice. Just weighed the alloy strut, its only about 300g, so not much weight saving on offer. I was going to recycle broken tiller ext as a strut so wouldn't cost much, but think I'd best stay with the old tech here. Pimping is a bit of a luxury.
![]() replacing with carbon tube is a waist of money edit: and it's going to get clobbered by the jib clew all the time. And carbon doesn't like that sort of thing. Edited by Jack Sparrow - 23 Apr 13 at 6:57pm |
Black paint?
tick ![]() Far too distracted from work ![]() Joined: 16 Nov 12 Online Status: Offline Posts: 223 |
self adhesive fake carbon......
Yep Jim is absolutely correct.
Resistance to buckling due to axial compression is a function of length of strut, Young's modulus and section inertia. In an application where the part would be expected to operate in a post buckled state, then the ratio of zero axis and off axis fibres would need to be considered in particularly thin walled applications, but I suspect this will be fine in a little strut. Just ensure that what you get fits the end pieces well, and that the load is taken by the strut and end pieces, not by any screws or rivets attaching the strut. If using mech fasteners take care to drill appropriate guide holes to te fastener, else it is easy to damage the laminate. |
Yes.
