Painting foils |
E.J.
Joined: 19 Feb 06 Online Status: Offline Posts: 184 |
Topic: Painting foilsPosted: 15 Mar 13 at 10:44pm |
I'm having some foils refurbed at a car body shop, The owner insists that car enamel is superior to 2 pack poly for marine applications. I cannot argue as I am only aware of 2 pack as an option, what is the truth; can car enamel be used as an acceptable paint for foils or is it black and white i.e. do not use?
Posted: 15 Mar 13 at 11:20pm |
car paint is pretty widely used, but has the reputation of being more easily scratched.
Oatsandbeans
Joined: 19 Sep 05 Location: United Kingdom Online Status: Offline Posts: 382 |
Posted: 16 Mar 13 at 7:54am |
2K acrylic car paint is actually chemically very similar (ie the same), as many marine polyurethanes, as they are often formulated with acrylic resins in them. So no problem there ( this is not cellulose 1K car paint though). When I have sprayed 2K acrylic onto foils I have always put on a good epoxy primer first to ensure that it all sticks. If this is a high build primer you can also use it to do a degree of fairing to the surface. The car paint shop should have something like this around, although they may want to use a polyester based material which (Will not be as good as an epoxy ).
jeffers
Posted: 17 Mar 13 at 8:15am |
What you need to get them to do is put plasticiser in the paint so it can flex without cracking otherwise you will find your lovely smooth finish might not last too long.
E.J.
Posted: 17 Mar 13 at 8:40pm |
That puts my mind at rest some what. The desciption I was given by the guy corralate with the answers you have given. Cheers.
E.J.
Posted: 22 Mar 13 at 6:02pm |
Just got the foils back from the shop and they look glass perfect. I am assuming that this perfect finish is unsustanable, but I hope that the paint responds well to boat polish. The paint certainly does seem to scratch more easily but this may be reduced in the long term when a more realistic and sustainable level of finish is acheived.
