LEE BOW EFFECT |
Page <1 45678 22> |
| Author | ||
G.R.F.
Topic: LEE BOW EFFECTPosted: 12 Oct 11 at 8:17pm |
In the meanwhile I've had another look at Eric Twinames section on tide, he does deal with it, but he also misses the essential part of the tidal equation, which maybe back in those days wasn't as relevant and probably because the stuff we sail amplifies the effect (Literally a favourable tide in certain conditions can make the difference between planing up wind and displacement speed).
Wether you believe what I'm saying or not and lets face it the back end of the fleet is full of doubting thomases, it is a fact as sure as day follows night. I'm available for lectures on tactical sailing in tidal situations...
Guests
Posted: 12 Oct 11 at 8:20pm |
That is the fallacy. The orientation of the boat's hull does not affect the direction it gets "pushed" by the current. |
rb_stretch
Joined: 23 Aug 10 Online Status: Offline Posts: 742 |
Posted: 12 Oct 11 at 8:46pm |
It depends on the angles. As soon as there is any component of the tide against the wind, you will get lifted. Basically means difference between tide and wind needs to be greater than 90 degrees and you will get some Lee Bow effect. At least in the definition I know..... |
G.R.F.
Posted: 12 Oct 11 at 9:30pm |
It's not to do with the boat or it's hull especially, it's the effect on the sail, via the increased pressure on the foil. The term is just a slang definition for ease of explanation.. er to the ESSR which it seems most dinghy folk appear to be at times..
sargesail
Joined: 14 Jan 06 Location: United Kingdom Online Status: Offline Posts: 1459 |
Posted: 12 Oct 11 at 9:31pm |
No it doesn't! The apparent wind is a combination of a moving volume of air (True or Ground wind) and a moving carpet (OK volume but in practice it's 2D) of tide (the tidal wind), and your boat speed and your angle to the wind (I'll call it induced wind). Pinching or footing changes the induced wind but it can not change the tidal wind.
sargesail
Posted: 12 Oct 11 at 9:35pm |
Taking the lee bow tide first, or lee bowing in the strongest tide is just a way of relating another of the great tactical rules - "Sail the major, dominant, long tack first" - to tidal factors.
sargesail
Posted: 12 Oct 11 at 9:36pm |
But we need someone clever to do some vectors!
G.R.F.
Posted: 12 Oct 11 at 9:50pm |
dude.. sailing 101. True wind generates movement. Movement generates "created wind" opposite to movement direction Both True and Created combined = Apparent wind. So Favorable tide on lee bow increases apparent wind by increased vector pressure on true wind Tide on weather bow decreases apparent wind inversely. Edited for accuracy..
Edited by G.R.F. - 12 Oct 11 at 9:57pm |
RS400atC
Posted: 12 Oct 11 at 10:01pm |
Quite succinctly put, Jim. One element that messes with your head is the fact that because the boat is slow relative to the ground, the apparent wind does not move forward as you expect it to, therefore you seem to be able to pinch without slowing the boat. This feels like a strange effect, which some people seem to roll into 'the lee bow magick' We tend to think in the 'land and marks' frame of reference, whereas the boat is operating in the water frame. |
sargesail
Posted: 12 Oct 11 at 10:37pm |
+1 Yep that explains the phenonomen I experience.
Page <1 45678 22> |
