New Posts New Posts RSS Feed: Design  Failrues....
Design Failrues....
 Post Reply Post Reply Page  <1 45678 9>
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Topic: Design Failrues....
    Posted: 21 May 10 at 3:54pm
There was a piece about it at the time when all had gone quiet for a while. I can't remember the exact story, but I pretty sure it was to do with the practicalities of the system, not the theory. I have a feeling we shall hear more from this technology - I certainly hope so.
Doug Lord View Drop Down
Post Options Post Options   Quote Doug Lord Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 10 at 4:11pm
Just a hint Doug, but there's no face lost in saying that things don't always
work out as planned and taking a step back to regroup behind closed doors is
sometimes the best way forward.... without trial and error the envelope will never
be pushed.
Thanks for the hint. I agree 100%. The thing is, though, on my foiler for instance, the bow design had a much more profound affect on low windspeed take off here in the short chop of the intercoastal than I anticipated-that was a design mistake by me that adversely affected one of the design parameters I felt was critical. But does that mean the aeroSKIFF was a design failure as Frump said?
I don't think so because of all the things that worked right(listed in a previous post). I don't think you can say that a boat is a design failure until it is put on the market and fails to perform.
My boat was a highly experimental foiler platform where the vast majority of the new, experimental stuff worked well or at least well enough to suggest more testing.
According to Jon and Linton the ventilated foil system designed and patented by Jon worked exceedingly well both on the Tomahawk and on a windsurfer. Again, I don't think you can say that the Tomahawk was a "design failure" since it was never put on the market and the technical aspects of the foil system worked very well.
Merlinboy View Drop Down
Post Options Post Options   Quote Merlinboy Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 10 at 4:44pm
Doug, i would like to echo TT's post, i wish you luck with your new venture.  Don't get drawn into sh*t flinging on here, for one thing this forum is moderated and forum bullying so to speak isn't really aloud to develop.  Please keep us up to date with your developments, but please don't keep posting the same pictures over and over again.  Otherwise i will get banned for giving you sh*t!
There is also no shame in admitting you were wrong, or something you have designed doesn't work!  Until there are pictures of the aeroSkiff foiling, we are all going to think it never flew!
Keep your chins up big boy!
chrishampe View Drop Down
Post Options Post Options   Quote chrishampe Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 10 at 1:18am
Originally posted by Neptune
Anyone remember Team Philips?
I'd
rather not...
Team Philips is interesting, it could have been a great
boat. I think they pushed the construction tech too far.
But if the structure of the boat had held together would it
of been competitive? I guess we will never know.
Chris Hampe
IC GBR 238
ASok View Drop Down
Post Options Post Options   Quote ASok Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 10 at 10:11am
Re:  Team Phillips
That definitely achieves design failure status.  The design of the structure failed, I believe.
Stunning boat and I understand that they really pushed the technology in boat building at the time, so the project probably had a lot of knock on benefits.
I'd have loved to have seen it complete the race.  What could have been........
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 10 at 10:10pm
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 10 at 9:06pm
Originally posted by ASok
Re:  Team PhillipsThat definitely achieves design failure status.  The design of the structure failed, I believe.Stunning boat and I understand that they really pushed the technology in boat building at the time, so the project probably had a lot of knock on benefits.I'd have loved to have seen it complete the race.  What could have been........
It would be really interesting to see a Team Phillips 2 that was built properly. I think in the years that have passed NDT tests have progressed to a level where bond adhesion can be properly checked, also the composite stressing techniques have evolved considerably, as the aerospace sector has started using CFRP for primary structure. The platform and rig concept were obviously deemed to have a benfit otherwise it would have ended up like all the other boats, so I guess it just needs someone with the balls to try it again. I was rather hoping the AC bun-fight might have re-created the concept!
ChrisC View Drop Down
Post Options Post Options   Quote ChrisC Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 10 at 10:24pm
I'd
rather not...
Chris Hampe
IC GBR 238
Mr Jardine - shame on you !!!!
Whatever the final outcome of the TP saga, it's really unfair and factually
incorrect to label it as a 'design failure'.
Like everything else Ade Thompson has done the design was stunning,
was light years ahead of its time and if things had been different (more
time, more money) the outcome could so easily have been very different.
The major structural failure of the bows was down to a basic construction
error (not 'design') as a result of a rushed build and perhaps inexperience
of the build team combined with a lack of testing.
With hindsight where the TP project probably went wrong was trying to
innovate on too many fronts, with too little money and too little time
carried along by Pete Goss' never ending enthusiasm.
From what I understand the performance on its maiden sail (from
Dartmouth to London) (thank God it didnt break on that trip) was truly
stunning and if you check out the final video shot as she headed out into
the Atlantic you will see that not only was she fast but also incredibly
stable (there is a guy casually standing on deck coiling a rope) - they
dont do that on Groupama or Bank Pop !
Compared with the other boats built for The Race TP was the only
innovative boat - everybody else played safe and built pretty tame
conventional cats (Ok Club Med looked cool out on her maiden sail but
where is she now ?!).
It still puzzles me why Pete Goss decided to head out in the North
Atlantic from the top of Scotland and then sail into the eye of a monster
storm !!!!! Non of the boats in The Race faced anything like those
conditions, even Loick Peyron's storm just before The Horn he was
heading downwind in big but organised seas. Non of those boats would
have survived that storm in the Atlantic.
What most people seem to forget is the spin offs from TP. The wave
piercing bow concept has been copied in Idec, Sodebo, BMW Oracle,
Alinghi 5, Banque Pop etc. The cantilever bows on Alinghi 5 were
probably bigger than on TP, the twin rig concept was copied (no where
near as elegantly though) on Yves Parlier's Médiatis Région Aquitaine
(24hr record holder). The un-stayed masts were pure genius apart from
the initial friction bearing issue.
If I won the Euro lottery I would commission TP 2 from the same design
team !
Edited by ChrisC
Not now Kato (you fewl) !
RS100 421 (8.4)
Ex - Vortex Assymetric 1090 and 1208
Ex - 49er NZL142 (crew)
zailor View Drop Down
Post Options Post Options   Quote zailor Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 10 at 7:53pm
elessar View Drop Down
Post Options Post Options   Quote elessar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 10 at 10:18pm
Well that is quite ugly however I think if you want an ugly unedited dinghy look to the BRITISH moth because I just
can't stand the look of that boat.
Its alright to dream
LASER - 102739
RS 300 - 483
BLAZE - 737
NATIONAL 12 - 3436
29ER - 716
