Standard of Proof? |
Page <1 34567 11> |
![]() ![]() ![]() ![]() Posted: 12 Jun 12 at 3:47pm |
But why would A shout protest? As far as she's concerned, B has acknowleged the infringement, and agreed to do a 2 turns penalty. In the pressure situation of a start, I can completely understand her not watching B the whole time. As far as A was concerned, the incident was over. It was only when she came ashore that she found out that B might not have actually completed her turns.
Do you shout protest at people after they've stuck up their hands and say they're going to do turns?
Yes, but if the boat does not then take the penalty turn, you're left high and dry: you don't have a valid protest to take to the room.
IF, big IF, there is acknowledgement of breaking a rule or a signal or indication that the boat would take a penalty, then we are looking at rule 2, no doubt. But I'm not confident that we can infer that from nothing more than a boat bearing away: maybe ohFFSake will dribble a little more evidence out to us in due course.
ohFFSake told us
That's an incident in the racing area that B is involved in, and C sees.
You're darn tootin B or C, if they intend to protest ... shall hail 'Protest', in accordance with rule 61.1(a). Edited by Brass - 12 Jun 12 at 4:03pm |
No ISAF case. There's RYA 1999/1.
I can easily imagine a situation where one boat is so stunned by what they see as an absoulutely blatent breach that they are truly astonished by the fact that the infringing boat isn't immediately doing turns that there are a few seconds between "Oi!" and "Protest (& flag)". Done it myself, I think (not the blatent infringement, of course, Pure as the driven snow, me.)
Again, a few seconds meaning exactly that. 30 isn't a few. Edited by Presuming Ed - 12 Jun 12 at 4:18pm |
Firstly, I think there is a case of not seeing the wood for the trees when hiding behind legal technicalities. Making me swallow a rule book before I can compete is not my idea of fun.
Secondly, in my uneducated opinion, I agree with PE. You don't protest someone for infringing a rule, you protest them for not exonerating themselves (including retiring). So first of all you have to establish that they are not going to exonerate themselves before you can shout 'protest'. And in this particular case, the first that B knew that A had not exonerated herself, was upon returning ashore - so there was no need to hail at the time of the incident if she believed that A knew she had fouled. edit: swapping my A's and B's! Edited by Peaky - 12 Jun 12 at 4:14pm |
OK, vaguely related hypothetical for you.
Cats (or Moths?) in the pre start, at 5 seconds to the gun. P (on port), infringes S. P immediately shouts "OK, doing my turns"; the helm holds up his hand and makes eye contact with the helm of S. Both boats are at the favoured end, there are a couple of rows of starters, so it takes her 20 seconds to get clear. S sails off at 15 knots, so 20 seconds takes her 140 metres away - say 20 boat lengths. She's fighting to hold her line, concentrating hard on the first beat.
P only does 1 turn (44 is not amended in the SIs.).
X (who started in the third row) tells S after the race that P only did one turn. X hadn't seen the initial infringement. She didn't know why P was doing a turn - she assumes she hit the pin.
Who should shout protest, when, and why?
Edited by Presuming Ed - 12 Jun 12 at 4:16pm |
Cut out the histrionics.
All you need to know is that if you think that another boat has broken a rule and want that other boat to be penalised, then you must hail 'Protest' and consipcuously display a red flag (if you are over 6m) at the first reasonable opportunity for each.
All the rest you can look up in the rule book at your leisure.
Well, your opinion, educated or otherwise is not in accordance with the rules and PEd never suggested that. By definition a protest is an allegation that a boat has broken a rule.
If you wait until a boat has failed to take a penalty in accordance with rule 44 before hailing 'Protest' you have not hailed 'Protest' at the first reasonable opportunity.
S should hail 'Protest' immediately she takes action to avoid P.
Because that's the first reasonable opportunity after the initial (P/S) incident occurs, and if P thereafter fails to take her rule 44 penalty, if S has not hailed 'Protest' at the reasonable opportunity, any protest she makes about the incident will be invalid.
Because it's easy and foolproof.
So suppose that S can't quite manage to hail one little word, which even the French can now understand and use, at the time of the initial incident, she's desparately trying to pin something on P, and wants to run a rule 2 protest, alleging that P deceived her by saying "OK, doing my turns" and not doing them properly.
To give you a decent answer about when the 'deception' occurred, I would want to look at some legal cases about 'misrepresentation about future events', which I will do tomorrow if I can.
But I think there's a little flaw in your scenario.
It's not a breach of rule 2 to not know or understand a rule: correct?
Then when P does 1 turn instead of 2, because she misunderstands the rules, she is not intentionally failing to comply with a rule, so she is not in breach of rule 2?
Obviously this is an old case but still in the casebook, substitute 'hail' for 'flag' and you have you answer. Perhaps the RYA should update this case to fit with the current rules for boats less than 6m? there are various questions under it but the preamble above gives us what we need here (IMO). The boat who felt they were infringed should have hailed protest. As for the comments about not learning the rules before going racing this is a bit naive in my view (and we have discussed this before). The RRS is a complex document but you should have a basic understanding before you go racing and then work on filling the gaps in (port/starboard, windward/leeward and inside boat at a mark is usually enough to start with when racing at club level). You sign up to say you are going to abide by the RRS when you sign on for a race....
Is ignorance an excuse? Perhaps at club level and with novice racers....
It does not exonerate you from failing to comply with the rules, but is on a lower plane than wilful cheating. |
Page <1 34567 11> |
