Weight equalisation |
Page <1 34567 13> |
![]() ![]() ![]() ![]() Posted: 03 Jan 22 at 9:38am |
Lot of cack handed thinking here. It’s the mast and sail attached to it that’s trying to tip the boat over. So just as fatter head sails have more adverse heeling moment so does having a wire attached to the mast high up to counter the heel What then happens the combine weight downforce is spread to weather . The bigger the wire angle the further to weather. Taller helms therefor being faster and able to sail the boat flat,
I agree with the issues having a too high hook would cause in lulls a consequence of my thinking marred by years of having a boom to hang on if necessary, but I think I might have a work around. The point still wrankles though as to why so many think it’s wrong |
Think about the angle the wire is from your body to the mast, it's not much off vertical, if you stood at the side of your boat and tried to tip boat on its side using the exact same angle, you wouldn't tip it over.
Robert
I believe professionally you where something in marketing I am an Engineer. The wire and where it is attached to the mast or the person has no effect of the righting moment. The only factors are total sail force, effective height of sail force, how far outboard the crew weight is and the crew weight Think about a TOY unstayed mast and sliding seat no wires, wind increases more force in sail sailor moves outboard more on the seat it’s that simple. The trapeze wire and the shrouds are irrelevant
Tink
As I said yesterday windsurfers are different because the mast mast is able to tilt relative to the position of the centre of buoyancy. I would draw another picture but it won’t have any impact on your thinking and I’m going sailing instead.
Tink
The wire is purely to support your weight, positioned correctly it offers support for your back.
Robert
I have a friend who is an engineer. He once told me that he spent half a night in a pub with a bloke who was convinced putting a wind turbine on his car to generate electricity as he drove along could feed an auxiliary motor to save petrol.
Nuff said.
So what’s now being suggested the Contender doesn’t need a wire and trapeze at all because you’re an Engineer and I’m in marketing?
![]() ![]() ![]() Edited by iGRF - 03 Jan 22 at 10:24am |
If the mast and the body were perfectly stiff, then you would have the wire at the tip of the mast and the top of the head, as that creates the least tensile force in the wire. The closer the wire moves to the foot of the mast and to your feet, the higher the tension in the wire. Actual positions are really determined by the highest, relatively stiff point in the mast (usually where supported by shrouds) and where our bodies are most comfortable with the force.
Page <1 34567 13> |
