Handicap - A Final Solution? |
Page <1 345 |
Author | |||
![]() ![]() ![]() ![]() Posted: 06 Sep 13 at 8:41pm |
timeonthewater ![]() Groupie ![]() ![]() Joined: 22 Mar 09 Location: United Kingdom, Arundel Online Status: Offline Posts: 60 |
IMS..when I was yacht racing was called the International mystery system.
Problem was, it was impossible to fathom for the mere mortal.. Far too many parameters, affected your handicap. Without the Deckman computer on board, we simply had no idea of how well were were racing, because our new racing mindset was now programmed to racing against the VPP's, and straight-line speed. Boat on boat action was avoided to a certain extent, unless we had the full after guard team, the tactician and navigator working full time to call whether it was worth tacking for speed, tactical or fleet advantage. 500K later....the one design J24 fleet racing was far more enjoyable You wouldn't wish VPP and polars on any club racer/race officer to make an IMS style handicap system work Graham..go sailing. None of this matters |
Too many toys..not enough time
i tick ![]() Groupie ![]() Joined: 15 Jul 13 Location: Tunstead Milton Online Status: Offline Posts: 93 |
I suppose that some of this matters if you cannot see where you are going or spot the next mark. Not a problem with point and shoot pond racing.
You could make a "one number" yardstick from a VPP, and use it in precisely the same manner as PY, but what I was driving at was that it would be every bit as imperfect as PY in trying to give a single number for all boats on all courses on all waters in all windstrengths. A stopped clock tells the correct time twice a day and all that. |
Ah yes, here as there (lee-bow) is Graeme stupid or pretending to be stupid. Dan H has, in a great post, shown clearly why your holy grail is a piss-pot with a hole in it!
So, that is what should happen, it would be based with some degree of fact. Not as things currently stand, a forever altering myth, dependant on input from Christ knows what and whom and or either a particular craft being witch hunted, or another favoured in an attempt to swell the coffers of certain regattas. So at least the time on the stopped clock would be a constant, as it is you never know when it will stop or who is slightly moving the hands in their favour or why. |
blueboy ![]() Really should get out more ![]() Joined: 27 Aug 10 Online Status: Offline Posts: 512 |
Not only but also...... Some rich guys in the USA sponsored the research that resulted in the MHS (later IMS, later ORCi and ORR) VPP in the 1970s and the current developers of the ORR and HPR rules are still sponsored by wealthy East-coast USA owners. All these years later, VPPs still aren't very effective for boats that plane or (worse) on/off plane as the latter is a significantly harder problem to model. Nor are they very good at predicting the relative performance of boats with significantly different typeforms which is why HPR(and IRM before it) is highly type-forming by intention. Dinghies are wildly more variable in typeform than modern racing yachts. Nobody has paid for development of an effective VPP for dinghies and I doubt anybody is about to do so. The idea that some simple spreadsheet is going to produce numbers more reliable than PY is a fantasy. P.S. AFAIK IRC is not VPP-based (in the sense of generating polars). You certainly can't apply to the IRC rating office for polars corresponding to your IRC certificate (whereas for ORCi you can). Edited by blueboy - 08 Sep 13 at 9:43am |
USA, IMS, ORCi, ORR,HPR, PY, P.S., AFAIK, IRC, .........WTF.?
Very true, but if there was some theoretical supplement to the PY then it might be useful for classes with fewer actual returns. Also, it is not beyond imagination that, say, Merlin Rockets will lower their hull weight rule. Rather than enjoying years of banditry whilst the returns come in, it would be possible to get a reasonable estimate of the delta. |
Page <1 345 |
